What's the limit on subwoofer size? - Car Audio Classifieds!
Old 03-05-2012, 02:58 PM
Wingman0121's Avatar
0/11 sssss2171
Default What's the limit on subwoofer size?
I see that 21 inches is about as large as a sub gets before it becomes really rare and really expensive, so what exactly is the bottleneck on building a really big sub? Assume that practicality and cost is not in the equation.
Old 03-05-2012, 02:59 PM
0/11 sssss6075
Demand.
The Following User Says Thank You to terra For This Useful Post:
Supergumby5000 (03-05-2012)
Old 03-05-2012, 03:02 PM
badmofo529's Avatar
0/11 sssss3329
most of the subs that are larger than that are gimmicks.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 03-05-2012, 03:41 PM
skinnyg's Avatar
0/11 ssssss828
I think cones strength comes into play, I guess if a manufacturer thought there was a demand they could have china make some 21" aluminum cones
Old 03-05-2012, 03:43 PM
skinnyg's Avatar
0/11 ssssss828
Amazon.com: Pyle PDW21250 21-Inch Performance Optimized High Power Subwoofer: Car Electronics
Old 03-05-2012, 04:08 PM
Benny33's Avatar
Hockey players, man...
0/11 sssss1616
With increased size comes increased weight(generally speaking). If you were to simply scale up the size of a woofer, you would also need to scale up the strength of the parts to be able to support/control the larger moving parts. You would also need to scale up the size/strength of the motor assembly to be able to control the movement of the cone and control it properly.
Look at the 34" audiobahn/cadence woofer. In short demos it worked, but it's practicality for everyday was just nonexistent. In order to make the cone rigid enough it was made heavy. The suspension and spiders couldn't support it and after a few months would start to sag significantly if mounted face up.
Look next at "The Bomb", Richard Clark's 5' woofer in a bread truck. This thing was built as a one-off, one-of-a-kind "speaker" to displace insane amounts of air to meter high. It's first design to see competition ate itself early on and had to be rebuilt. The frame, in this case, could not support the forces being exerted on it by the ridiculously powerful motor and substantially large cone assembly.
I'd say even the 21" you mention is not an everyday woofer. You really don't see more than a handful of manufacturers making them and most of them are in pro-audio setups where excursion is not as extreme as car audio.
Yous just figures that out? All the hots ones is crazy!...And deh ugly ones too. - Toki Wartooth
1000 Character Limit for FS Threads?????? BassAddictJ Announcements - Suggestions - Feedback - Support 10 08-29-2011 06:44 PM
Does enclosure size effect subwoofer cooling? burzendowski General Car Audio Discussion & Questions 3 08-05-2011 11:50 AM
Subwoofer voice coil size? Oldbass38 General Car Audio Discussion & Questions 12 03-22-2010 06:56 AM
PM Box limit madmat Announcements - Suggestions - Feedback - Support 3 10-26-2008 01:40 PM
