Fusing for large amps/power - Car Audio Classifieds!
Old 03-05-2012, 08:26 PM
Captain Tying Knots
0/11 sssss1220
Default Fusing for large amps/power
How do you guys do it? This is going to be my first big power (well, big for me) build and I need help learning to fuse for bigger power. The amp I will be using is a Stetsom 7K D and I'm buying dual inputs for it from Woofer Warehouse, so 2 runs of 1/0 each for positive and negative. Would I be able to get distro blocks that have 2 1/0 inputs and outputs and use two 240 amp fuses per block? Any input/tips are immensely appreciated.
TEAM NWSPL
Old 03-06-2012, 07:19 AM
vince79vette's Avatar
0/11 sssss2011
From what I have been told is that u fuse what your alt puts out
Old 03-06-2012, 07:21 AM
0/11 ssss31255
don't "fuse for what the alt puts out"
fuse your wires for what the wires can carry.
fuse your amplifiers for the maximum current they could draw at 12 volts.
[trust me, you don't want to exceed that amperage or drop below 12 volts]
(or fuse your amps for what the wires can carry... but you shouldn't be using wires which can't carry the max the amp can draw)
Old 03-06-2012, 07:31 AM
0/11 ssssss542
I don't use fuses, this site has 400A+ fuse blocks.
ANL Type Fuse Block 750A Max with Cover Blue Sea 5503: 5503_Blue_Sea Genuinedealz
I don't know what the current draw on a 7K is but 240A seems too low. Just because you run multiple wires, it won't evenly devide the power in each wire. You want the fuse to me rated for at least the maximum draw of the amplifiers.
Old 03-06-2012, 01:58 PM
Captain Tying Knots
0/11 sssss1220
What I could find was 480 amps max draw. So should I go two runs of 1/0 with dual inputs or a larger gauge wire?
TEAM NWSPL
Old 03-06-2012, 03:46 PM
twentyhurtz's Avatar
0/11 sssss1335
I'm using 300a Knuconcepts fuses with the Open ended ANL plastic fuse blocks. I use these and cut the ends off using my dremel because the opening is made for 1/0 wire. I'm running 3/0 and because the ring terminals are so large i have to modify the holder. I have double stacked fuses before in a holder (only could find 150's at the time).
Old 03-06-2012, 08:32 PM
Actually, it will. There might be small variations because of minor resistance issues, but not enough to matter.
And the rule is : FUSE FOR THE WIRE. If the amp isn't going to draw as much amperage as the wire is capable of carrying, it's fine to fuse lower. You will be fine with the dual 240 amp setup.
Old 03-06-2012, 08:36 PM
0/11 ssss31255
I use a uni-bit by hand to enlarge the wire holes in the barrel style ANL fuse holders.
Old 03-06-2012, 09:10 PM
gti1.8t's Avatar
0/11 ssssss361
Would u guys mind posting pics of the "modified" fuse holders? I'm curious since I'll be doing the same this summer.
Purchased from: dbass,
Old 03-06-2012, 11:40 PM
0/11 sssss1335
i will try to remember to take a picture tomorrow. It's not pretty so i currently have mine wrapped once in gorilla tape since the crappy plastic covers don't like to stay snapped on. The are some cheap install bay anl holders.
Large lot of amps for repair. ghostmechanic Broken & Non-working equipment 27 12-14-2011 08:49 AM
list of large class ab amps ellocojorge General Car Audio Discussion & Questions 25 11-30-2011 11:09 AM
Large Quantity of Used Sundown Amps sundownz (Sundown Audio) 64 10-25-2010 07:45 AM
WTB/WTTF Large Sub Amp/Amps 4-10 KW sound_around Wanting to Buy (WTB) 22 08-11-2010 08:45 PM
