reserve battery size - Car Audio Classifieds!
Old 03-06-2012, 08:26 AM
0/11 ssssss200
Default reserve battery size
i want to get a second battery for my suburban. i have a sears plat. as my main battery and a dc 270 as my alt. i am running 4 kenwood amps. 2 xr1s running at 2 ohms for 700 watts each and 2 xr4s running 300 x 2 at 4 ohms. i also have 6 7" screens and 2 22 screens and a xbox 360. i want to be able to run my system at shows while the engine is not running. whats the smallest battery i can run? the space i want to run it in is small. but if not i will get a regular size battery but i want a small battery. thanks in advance.
Old 03-06-2012, 08:51 AM
0/11 ssssss830
Lol you have all that running on 1 batt How many amps are u drawing from the amps alone
Old 03-06-2012, 09:07 AM
0/11 ssssss200
yep and i have no issues as long as the truck is running. im not sure how many amps i am pulling. i figure 60x2 30x2 in amps maybe another 50 in others (monitors and xbox) plus whatever the stock things are pulling. but we know the amps will not pull it's full load. so i should be under the amps the alt. is putting out. so whats wrong with that. is my thinking wrong?
Old 03-06-2012, 11:21 AM
0/11 sssss1016
If you go with a small battery you will have a short run time. Going to have to use a Group 31 battery to have much of a run time at all.
'1.888.497.7693 x1211
Old 03-06-2012, 12:31 PM
0/11 ssssss200
i'm lost on the group sizes. give me the dumb version.
Old 03-06-2012, 12:38 PM
badmofo529's Avatar
0/11 sssss3329
get an xp3000 or 2 from the group buy
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Battery size? Fatboy501 General Car Audio Discussion & Questions 0 03-03-2011 07:45 PM
What size battery? dadydolas General Car Audio Discussion & Questions 3 07-20-2010 08:42 PM
A battery, and what size? Novicaine General Car Audio Discussion & Questions 9 07-12-2010 03:13 AM
battery size Bob Saget General Car Audio Discussion & Questions 2 04-19-2010 09:43 PM
What Size Battery? cmwilson General Car Audio Discussion & Questions 11 02-16-2010 09:11 AM
