Stock alt plus mechman questions - Car Audio Classifieds!
Old 03-06-2012, 12:20 PM
0/11 ssssss188
Default Stock alt plus mechman questions
Well I've had my mechman 250 amp alt for a while and it does well. It has the built in adj regulator on the back. I'm wanting to to install my factory alt along side it. What's the simplest way to gain the extra 105 amps of charging from this alt? I know I can create a separate circuit for my highs and vehicle electric but I'd like the extra current available for the rear batteries and sub amps.
Old 03-07-2012, 09:04 AM
MECHMAN's Avatar
0/11 sssss1142
Your best plan would be to isolate the Mechman unit to your subs and run the stocker for your vehicle and mids/highs. Otherwise you would need to have common regulation in order for the units to work together properly.
Old 03-07-2012, 11:47 AM
0/11 ssssss188
If I get another say 200amp externally regulated alt could I use a single ext. Regulator to control both?
Can I get away with having a stock alt? DevinG17 General Car Audio Discussion & Questions 21 02-27-2012 09:43 AM
my new mechman alt Hertchu General Car Audio Discussion & Questions 0 02-21-2012 10:54 AM
Stock 140a Alt for GM 3800 Series II or a cheap HO alt Raptor660 Wanting to Buy (WTB) 10 04-08-2011 07:11 PM
[NLFT] Blazer 200 amp H.O. Alt- trade me your stock blazer alt Bushj311 Wiring, Electrical & Other Installation Equipment 52 05-19-2010 11:59 AM
Mechman alt vs. Powermaster alt strpperpolef150 General Car Audio Discussion & Questions 9 09-11-2009 03:26 PM
