4th order experts guidance needed - Car Audio Classifieds!
Old 03-06-2012, 10:46 PM
doug118's Avatar
0/11 sssss4674
Default 4th order experts guidance needed
I hate to make another 4th order thread but I've been reading through them on a few forums all night. I would like to design one myself to save some money since the only good 4th order designers I've found want like $40+. I don't need a fancy 3d sketchup, that's what I have a imagination for.
I just have some questions to help figure out what to do here. I know the basic ratio is 2:1.
I'm looking for a fairly flat response from around 25hz-50hz. How do I go about figuring what to tune the front chamber to? Is 15 sq/in of port per cube typical for these enclosures?
Also, how do 4th orders effect the handling power of the subs?
subs are 2x sundown sa-12's
Max dimensions are 35l x 30w x 19h
I'd like to port through the ski hole, which is 8" x 17.5"
Old 03-06-2012, 10:50 PM
0/11 sssss1286
I can get u a design for half of what u posted .. But depending on power used u could go with a 2:1 and 15-20sq per cube
Old 03-06-2012, 10:53 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
The best thing I can recommend is making your box as big as possible and then just playing with it, I just recently built a 4th order for my maxima and asked for a starting point and was never answered so I just rolled with. But yea a good ratio to keep in mind is 2:1. I hope I helped some man
Sent from my MB870 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 03-06-2012, 11:01 PM
doug118's Avatar
0/11 sssss4674
I'll be running them off of a sundown saz2500
How much for just dimensions for everything? I don't have that much cash to spend on a design at the moment
Thanks. If I had easy access to tools I would just wing it and see what happens but I use all my fathers woodworking stuff and he lives an hour away so that would make it a pain in the ass
Old 03-06-2012, 11:09 PM
0/11 sssss1286
$20
Old 03-06-2012, 11:13 PM
doug118's Avatar
0/11 sssss4674
So same price whether you do a 3D design or not?
When figuring out port length, do I design the ported portion just like I would if I were building a normal ported box?
Old 03-06-2012, 11:20 PM
0/11 sssss1286
$20 will get u basic layout plans
And no
Old 03-06-2012, 11:26 PM
Awaiting Confirmation
0/11 ssssss923
Pm me I can draw you up something just need your max demensions
CAR: 1996 Cherokee sport
WIRE: 4 runs of 2/0
SUB: 3 NSV1 18's
AMP: 3 SAZ-3K's
BOX: 4th order wall
Old 03-08-2012, 01:17 AM
0/11 sssssss24
one word, winisd.
Old 03-08-2012, 01:20 AM
0/11 sssss3986
Originally Posted by nubz69 View Post
one word, winisd.
one word, FAIL
The Following User Says Thank You to 2000LaDe For This Useful Post:
ascitiesburn69 (03-08-2012)
4th order design needed LivinLoud08 Enclosure Discussion & Design Construction Help 17 03-04-2011 06:01 AM
Car experts needed RollerDJ General Automotive Chat 24 05-28-2009 07:58 PM
