Some MECA rule help please... - Car Audio Classifieds!
Old 03-08-2012, 08:43 AM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Default Some MECA rule help please...
So since I won't be able to compete with my truck I've been contemplating doing a couple shows with my car instead and will be staying in the S1 class for this one. I'm confused on the fuse ratings though...I was thinking of using a DC 1.2K but it has onboard fuses. For S1 there can only be one fuse and the rules say if there is no inline fuse then the onboard fuses are used to determine the rating.
The DC 1.2K has 3x40 amp onboard fuses so in theory that amp would put me in S3. I'm wondering if I can either remove 2 of the fuses to maintain a single fuse at say 50 amp for burps or if that amp could keep the onboard fuses and still keep me in S1 (highly doubt it lol)
Thoughts?!?
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 03-08-2012, 09:19 AM
Ego Crusher
0/11 sssss1834
Not sure on the number of fuses but you can lower the fuses to say 3 15amp fuses and burp it like that
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 03-08-2012, 09:24 AM
Ego Crusher
0/11 sssss1834
What I did it just bought agu fuses and holders and just cut the power wire to the amp and added them.
Old 03-08-2012, 09:28 AM
turkishvalo's Avatar
0/11 sssss1418
From what i understand they dont count the fuses on them as long as you have an inline fuse near you amp or rear battery. I plan on using a mini anl in as1. Why not just use an inline? Just curious.
HU-Pioneer DEH-7200HD
Front Stage-CDT EU6s Alpine SPR-10TW tweeters,
Front amp-PPI 900.4
Sub stage-2 Fi btl 12s
Sub amp- 2 Crescendo BC2Ks Strapped at 2
Mechman 240. Team gg.
Old 03-08-2012, 09:48 AM
0/11 sssss1463
Feedback Score: 21 reviews
what sub are you using. I think for onboard fuses they just add them together. I wold just call steve to make sure though.
Contact me to get orders for any of your B2 Audio needs. I am an Authorized Dealer
REFS-DAPPA5, BRIAN OWENS, --Navi-- , X1le, Basscort2009, vitveet, thumpper, Lousiana_CRX, woofercooker, tez4life, 913 customs, davidrforbus, bluieorbluee, lil98cabrio, Dropped_TB, orangecounty1, dbeez, Seifert, JB Livewire, rmaravetz, 72impala
Old 03-08-2012, 09:54 AM
0/11 sssss1068
They don't count the amp fuses as long as you use I online fuse that's within 18 inches of the amp. If you use the amp fuses as stated 3x30 you might be able to use a 6 1/2 inch sub and that's it. So use a inline fuse and save yourself
The Following User Says Thank You to jb livewire For This Useful Post:
turkishvalo (03-08-2012)
Old 03-08-2012, 11:03 AM
jhg33k's Avatar
0/11 sssss1531
Awesome info guys...thanks! So I can keep the onboard ones in tact as long as I use an external inline? I have no problem doing this and I really didn't want to use the onboard ones lol...I'm going to be running a single 12 for this setup. Haven't decided yet on if I'm going to run my PSI built 12 with 4" coil or get a new M2 Level 3 or 4 12"
I have 40 amps to play with and I'm sure I can burp the 1.2K with a single 40 AGU. But if I add the 40 amp AGU the onboard ones are basically not counted...is this correct? I need to be sure because I'm about to start purchasing based on this so I want to be 100% sure...
Thanks again for everyone who put their .02 in
Old 03-08-2012, 11:14 AM
0/11 sssss3986
bypass on board fusing with wires and male end connectors. and use an inline fuse.
The Following User Says Thank You to 2000LaDe For This Useful Post:
jhg33k (03-08-2012)
Old 03-08-2012, 11:15 AM
jhg33k's Avatar
0/11 sssss1531
Can't believe I didn't think of this...I think that's what I'm gonna do! Thanks bro!!
Old 03-08-2012, 11:43 AM
0/11 sssss1418
Honestly i wouldnt use agu though, ive had bad luck with them. The solder always seems to break. They make fuse holders that can hold anl and mini anl. They have 2 sets of screws on them. Tsunami makes one that im getting. Just a suggestion.
Front amp-PPI 900.4
MECA Question jessdabest77 General Car Audio Discussion & Questions 3 01-13-2012 10:14 PM
MECA Bakersfield CA 3/5/11 premierdime Cali Sounds 142 03-07-2011 09:50 PM
MECA djarmy2004 General Car Audio Discussion & Questions 32 02-14-2011 08:10 PM
MECA mcintosh at asylum General Car Audio Discussion & Questions 88 11-25-2010 11:55 PM
9-11 MECA 2X Hammond,IN Rogers Competition Corner 4 09-08-2010 07:15 PM
