Stetsom 5k2d 2 ohm model @ 1 ohm??? - Car Audio Classifieds!
Old 03-08-2012, 04:16 PM
usampsman's Avatar
Awaiting Confirmation
0/11 sssss1742
Default Stetsom 5k2d 2 ohm model @ 1 ohm???
Do they hold up? Im tryng to figure out my sub situation and everything i have lined up is d1 pairs!!! I know ill have rise and all that fun stuff but has anyone ran them at 1 ohm?
TEAMHEAVYHITTERZ... CURRENT BUILD IS FOR YOU LOCAL HATERS
Old 03-08-2012, 04:54 PM
528hz's Avatar
0/11 sssss1792
"Most" of the Stetsom amps, the 2 ohm versions, will run at 1 ohm. Stetsom just doesn't recommend it mainly because they will get that much hotter.
However, if you're talking about a NOMINAL 1 ohm ohm load, with rise you will be plenty fine. I've personally done it on a 2k6d; it was a nominal load of 1.2 ohms...
"When people think you have anger issues, your schedule clears up..."
Stetsom 1K6D (1750W @ 2 Ohm) surreal General Car Audio Discussion & Questions 4 12-04-2011 09:30 PM
Stetsom 14k2d 18 volt 1 ohm nmachado99 Mono Amplifiers 7 12-01-2011 10:27 PM
FS: Stetsom 14k2d 1 ohm modded tahoefixssd Mono Amplifiers 17 11-04-2011 09:33 AM
Stetsom V1K5H - 1 Ohm oldsch00lf00l Mono Amplifiers 12 07-13-2011 04:17 PM
FS FS JBL top of the line model 1400 RMS @ 2 or 1 ohm, CHEAP!!!!!! sotelomichael Mono Amplifiers 3 04-29-2011 02:02 AM
