amp cutting out - Car Audio Classifieds!
Old 03-09-2012, 12:39 AM
Brand New Members
0/11 ssssssss2
Default amp cutting out
just threw a fosgate 10 in my truck with my us amp on it and the amp is cutting out. I look back and the power light is off. I can turn the radio off and back on and it will come back on sometimes. Any Ideas?
Old 03-09-2012, 12:43 AM
Gabriel ruiz's Avatar
1/11 sssss1458
Feedback Score: 37 reviews
i would turn off my car and recheck your wiring it could be a lose ground or something make sure everything is tight and secure and try it again if that dont help check if your sub is wired correctly thats is all i can say for now
Old 03-09-2012, 12:46 AM
sleepingciv's Avatar
0/11 sssss1936
Feedback Score: 31 reviews
voltage drop maybe?
Old 03-09-2012, 12:49 AM
Brand New Members
0/11 ssssssss2
I was thinking voltage drop, I have a capacitor I was planning on throwing on it to see if it helps. Its an old mighty max truck that i am sure not set up to handle the power. We will see whats up. The ground might need to be moved as well I bolted it to the side of the truck to a screw that was attached to the inside paneling.
Old 03-09-2012, 12:52 AM
nmachado99's Avatar
0/11 ssssss391
Loose remote wire maybe. Does the amp cut off at a certain volume on the headunit?
Old 03-09-2012, 12:53 AM
0/11 sssss1936
do the big 3 if you havent
amp cutting out Koteman General Car Audio Discussion & Questions 8 11-09-2011 05:52 PM
amp cutting out mwerling1212 General Car Audio Discussion & Questions 9 03-09-2011 09:28 PM
Amp cutting on and off? oonegro General Car Audio Discussion & Questions 0 02-01-2011 05:03 PM
magna bass amp completely cutting off. daqid General Car Audio Discussion & Questions 0 06-09-2010 06:41 PM
Amp glitchin or soemthing?? Keeps cutting out, tried everything W O T General Car Audio Discussion & Questions 46 10-19-2009 12:52 PM
