Big 3 question - Car Audio Classifieds!
Old 03-09-2012, 02:50 PM
0/11 ssssss211
Default Big 3 question
I have an 03 s10 and im wanting to do the big 3. My question is do i leave the factory wires where they are and just add the 0 guage wire right from the + terminal to the alt and - to the frame and then right to the block using existing grounds.
Thanks.
Old 03-09-2012, 02:51 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
It won't hurt to just leave the factory wires just where they're at.
Old 03-09-2012, 02:54 PM
0/11 ssssss211
I didnt think so i just wanted to make sure. Cause the wire that comes off the alt looks like it goes down to the starter and back up. It doesnt go straight to the battery.
I just dont want to mess anything up. I know you guys know everything i need to know about car audio and appreciate the info!
Old 03-09-2012, 02:59 PM
0/11 ssssss816
Feedback Score: 22 reviews
yeah I would leave the factory wires alone. More paths for current to flow is never a bad thing, and that way, you don't have to worry about excessive current flow through the new wiring from all of the vehicle accessories. They will only cause more voltage drop and starve the amp, if you take away the OEM wiring.
Old 03-09-2012, 03:56 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
I wouldn't touch the factory wiring at all. Just add to it.
Sent from my HTC EVO 3D
Old 03-09-2012, 04:20 PM
0/11 ssssss211
So just take the 0 guage right to the alt from the + terminal. Im wondering about possible feed back due to the factory wires going down to the starter first then back up to the battery.
Old 03-09-2012, 04:33 PM
oslouie's Avatar
0/11 sssss5073
Thats how you do it. Don't worry about the other wires.
Old 03-09-2012, 09:13 PM
vince79vette's Avatar
0/11 sssss2011
The more wires the better. Just keep adding
Old 03-09-2012, 09:19 PM
0/11 ssssss211
That sounds like the plan!!! I just need about 2 more feet of 0 guage and ill have enough to do the big 3. I have the run from the battery to the alt and frame to the block but i need the run from the battery to the frame.
Old 03-09-2012, 09:32 PM
oslouie's Avatar
0/11 sssss5073
Batt to frame is more important than batt to block, IMO.
Question about big 3 sleepingciv General Car Audio Discussion & Questions 2 03-12-2011 11:55 AM
Big Big question, need help... masterbarber General Car Audio Discussion & Questions 31 10-13-2010 09:12 PM
Big 3 Question Jayrulz223 General Car Audio Discussion & Questions 1 07-02-2010 02:47 PM
Big 3 Question Ronin General Car Audio Discussion & Questions 14 10-05-2009 11:42 PM
big 3 question tater General Car Audio Discussion & Questions 38 12-08-2008 08:51 AM
