Breaking in sub GETS HOT - Page 3 - Car Audio Classifieds!
  #21
Old 05-09-2012, 02:10 PM
99technine's Avatar
0/11 ssssss399
Theyre DVC 4 ohms wired in parallel to 1. gonna recheck wiring, check for clipping and tune the amp after work. results will be posted later. I also got an idea from someone else that msgd me that my box could be too close to my back trunk wall and just sucking in the hot air its pushing out. Although that should make the other sub at LEAST warm correct?
Rep- MN [952]
Old 05-09-2012, 02:15 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
the leads could of been soldered backwards on the recone as well.
  #23
Old 05-09-2012, 02:16 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
That's some funny shit right there! I don't think this has anything to do with your problem. You need to pull the sub and check its wiring. The check the wires going to the box from the amp. Then check the wires at the amp.
  #24
Ja Marcus
0/11 sssss6975
I highly doubt it if it was sent back to Jacob for repair.
  #25
Old 05-09-2012, 02:29 PM
0/11 ssssss452
  #26
Old 05-09-2012, 02:41 PM
tacomaguy1's Avatar
0/11 sssss4401
check phase with a 9v battery or something...touch + and - to batt, if they both move the same way it's good. If not one is wired out of phase
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
  #27
Old 05-09-2012, 04:35 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
dude, do you ever listen to your system at 1/4volume, same thing.... thats "under powering the subs." you are so far from right that its not even left, you created a whole new direction
this, both subs in perfect unison, or check each individually
TeamGG
Team D.O.A.
The Following 3 Users Say Thank You to Decaf For This Useful Post:
813thumper (05-10-2012), KTMrida4life (05-16-2013), XORstatus (05-10-2012)
  #28
Old 05-09-2012, 09:35 PM
99technine's Avatar
0/11 ssssss399
lol...
got grimeballed at work had to stay late gonna check everything now.
Rep- MN [952]
  #29
Old 05-09-2012, 11:04 PM
99technine's Avatar
0/11 ssssss399
so im speechless...
well not really. I found out i f'ked up all the wiring. I TRIPLE checked it and went out to bump em.. they WANG. PERIOD.
Rep- MN [952]
  #30
Old 05-09-2012, 11:21 PM
Decaf's Avatar
0/11 sssss3460
so im speechless...
good stuff, sometimes another person to check helps before applying power to assure proper wiring
TeamGG
Team D.O.A.
breaking in sa-15 ianlahood13 (Sundown Audio) 5 06-05-2011 11:55 PM
Breaking in a new Sub Scruffy_Nerfherder General Car Audio Discussion & Questions 11 03-24-2010 11:23 AM
Breaking in a nEw sub MaTT6387 General Car Audio Discussion & Questions 25 11-14-2008 04:54 PM
Hot Rods N Hot Bods at The Mens Club ~ CHARLOTTE NC ~ 11-16-2008 CACO's Car Show Bot Car Show Feeds 0 11-09-2008 02:10 AM
Hot Rods N Hot Bods 600.00 CASH PAY OUTS ~ CHARLOTTE NC ~ 10-25-2008 CACO's Car Show Bot Car Show Feeds 0 10-13-2008 02:01 AM
