Component system help - Car Audio Classifieds!
Old 08-28-2012, 05:10 PM
0/11 ssssss320
Default Component system help
ok so today i tuned my skar 1500 with a dd1 sounds amazing but now whats happening is it seems my component speakers are distoring like there being pushed to far i increased my head unit volume from 38 and now its 48 and then it clips so im wondering what would keep these speakers from soundsing like there being pushed to much the thing is that there running of my head unit i dont have an amp for my component speakers could that be the problem that im pushing them past what the head unit can push them do i need an aftermarket amp for them also my buddy was telling me take them 6x8 and 6x9 out and put some 6.5s in my lincoln town car that round speakers are better for sound another prooblem that seems were running into is the components are too bassy so what im asking is do i need an aftermarket amp to power these to keep them from being to bassy and give me crisp clear sound ? are round components better then oval component speakers oh and i was pioneer component speakers in there now thanks there coaxial speakers
Old 08-28-2012, 08:52 PM
0/11 ssssss320
so any suggestions
Old 08-29-2012, 12:30 AM
schmiddr2's Avatar
ΞΞΞΞΞΞΞΞΞΞΞΞΞΞΞ
0/11 ssssss428
Could be clipping them or you might not have the highpass crossover set high enough so they would be exceeding their xmax at lower frequencies. Or they don't have a lot of xmax to begin with.
Sound is not oval or round so it does not make a difference.
An aftermarket amp has a lot of benefits. If your HU is clipping then it would help with the problem too.
What speakers are you using?
Old 08-29-2012, 01:22 AM
villeza1's Avatar
0/11 ssssss544
You do realize you can find the head unit's limit by using the DD-1...right?
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 08-29-2012, 09:33 AM
0/11 ssssss320
yea i did that my boy came over with his dd1 from what i thought to get the hu max i thought you use the 1000htz tone and use the rcas from the head unit but he did it another way he used a 40 htz tone and jusst put the pos to pos of amp and neg to the ground of amp not sure if you cn also get your max volume that way but my speakers are pioneer coaxials there like 60 bucks from sonic 6 by 8 in door and 6 by 9 in the rear
Old 08-29-2012, 03:30 PM
villeza1's Avatar
0/11 ssssss544
You guys should have did it with BOTH tones, and depending on the music you listen to (rap, bass boosted) you would have needed to use either the 40hz -5 or -10 db tracks and the 1kh -15 db track to find where the h/u clips. There should be 2 different points where the h/u clips, and you would use the lesser of the 2.
The RCA's should have been connected from the h/u to the DD-1, OR through the sub amp (for the 40hz tone only) with the amp gain all the way down turning up the h/u volume until the clip indicator light illuminates.
2 AB 1100.1's
Old 08-29-2012, 03:38 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Frank you should amp them anyways, you will be able to fine tune them and make them sound better then you will be able to do with the HU.
Old 08-30-2012, 06:19 AM
dcollister440's Avatar
0/11 ssssss713
Ryan you got an o-scope or a dd-1?
Emerald Green 1996 Lexus ES300 DEH-980BT Focal 165vr Rockford P400-4
FI BL 4^3 @32hz [email protected] .4
Diehard plat 34/78, 2 Diehard plat g31s(trunk)
Knu OFC, Stinger level 3 RCA's, Clarion EQS746
Dampro, Viper 5701+rem start
Old 08-30-2012, 12:43 PM
0/11 ssssss320
So i think imma get the skar 85.4 and then maybe get 6.5 polk mm6501 or some pro audio maybe crescendo what you guys think about that
Old 08-30-2012, 12:46 PM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
Pro audio will be much louder but you have to run active crossover points. Make sure you can do that with your head unit (or maybe the amp can if the points go high and low enough)
____________________________________
IASCA Pro AM and MECA Modex -->
Infinity Kappa 5 two-way component system (50.9CS) - Used Mummbles Marketing Component & Coaxial Speakers 4 08-31-2012 12:54 PM
FS: BNIB Dynaudio Component System 240 Mk II snaimpally Component & Coaxial Speakers 4 02-26-2012 11:33 PM
Rockford Fosgate P1682S 2-way Component System d77543020 Component & Coaxial Speakers 3 11-03-2010 09:25 AM
MB Quart PVF 213 Component System benzmansl65amg Component & Coaxial Speakers 11 04-30-2010 02:41 PM
Jl Audio XR653-CSi 3-way Component System swilber08 Component & Coaxial Speakers 4 02-22-2009 01:35 PM
