6th Order Compound Loaded Isobaric Bandpass - Car Audio Classifieds!
Old 08-28-2012, 09:06 PM
LoudnProud's Avatar
0/11 ssssss992
Question 6th Order Compound Loaded Isobaric Bandpass
Was scanning youtube and came across this design. Even though some may hate just posting for the visual of what we are talking about:
6th Order Compound Loaded Isobaric Bandpass Box - 2 12" Woofers - YouTube
Has anyone tried a similar box out in their ride?
How would a box like this work for posting numbers?
Just curios what everyone thinks...
Let me know bassheads
Loud n Proud
Old 08-28-2012, 09:21 PM
It's just a parallel 6th order, and just by looking at it probably not a very good one. Numbers will be identical to a single driver setup, but because it's an isovent design you can reduce chamber volume.
A quick question for those who have used those subs: is that mechanical noise (when the side baffle was off) coming from the subs? That's horrible if it is.
Old 08-28-2012, 09:32 PM
Infinitelybaffled's Avatar
0/11 ssssss816
SM said it was a huge fail. I'd agree with that as parallel tuned 6ths usually blow. Series tuned 6th are where it at.
Inappropriate sig image.
The Following User Says Thank You to Infinitelybaffled For This Useful Post:
profundus-sanus (08-28-2012)
Old 08-28-2012, 09:42 PM
Me > Lord Van
0/11 sssss2831
I've only seen one good parallel tuned 6th order and that was in team livewire's old caravan.
Every other 6th order I've seen has been a series tuned.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Old 08-28-2012, 09:51 PM
LoudnProud's Avatar
0/11 ssssss992
So no added efficiency from having the woofers push/pull each other in this type of setup?
Old 08-28-2012, 09:57 PM
0/11 ssssss999
Feedback Score: 43 reviews
my parallel tuned 6th order dose well for me ill have to get some pics of it up some day
Old 08-28-2012, 10:04 PM
LoudnProud's Avatar
0/11 ssssss992
Would be interested in seeing some of those pics for sure. Daily build?
Old 08-28-2012, 10:15 PM
irpirate might disagree with you.
No.
Old 08-28-2012, 10:20 PM
Me > Lord Van
0/11 sssss2831
No.
ipirates was a series tuned last I remember.
A parallel tuned 6th order would have two separate ports firing into the cabin.
Unless I'm mistaken on his build, he had two ported chambers (one on each side), subs in a clamshell, all of which fired out of one center port.
EDIT: Yep, I was right.
That would be a series tuned 6th order.
Team DOA
10 inches of terror
Old 08-28-2012, 10:40 PM
0/11 ssssss999
thats the skp of it 4 9518s in a astro 65-70 cubic feet before dis
6th order bandpass for Justin (bubba906) [Completed] Bubba906 General Car Audio Discussion & Questions 50 11-22-2012 08:48 PM
6th order bandpass awesomeness designed by surreal sho412 General Car Audio Discussion & Questions 18 02-06-2012 07:41 PM
What do you think about my 6th Order Bandpass Box Jdubs04ss General Car Audio Discussion & Questions 9 05-11-2011 12:59 PM
6th Order Bandpass Information jagblazer01 Enclosure Discussion & Design Construction Help 23 04-18-2011 02:55 PM
Ported vs 4th vs 6th order bandpass sdelthon General Car Audio Discussion & Questions 20 10-19-2009 03:05 PM
