fellow sub builders. - Car Audio Classifieds!
Old 08-30-2012, 03:44 PM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
Default fellow sub builders.
So im bolting a ti basket to my soundstream xxx motor. The bolts are positioned to the back of the bolt holes like in the picture. Should i use a washer under the bolt or will it be alright? Each bolt is like this..
Ps. i obviously plan on using ca glue also
Old 08-30-2012, 03:51 PM
Mr.G6's Avatar
0/11 sssss4614
for personal preferance i would put a small washer ..
but i have seen many people do it without adding a washer... but in my eyes thats alot of ass hanging off that thing and id want a little more surface area contacting the basket
2000 Gmc Sonoma ext cab
Old 08-30-2012, 03:58 PM
AudioAnonymous's Avatar
0/11 sssss1723
Buy Shorter bolts?
CACTUS SOUNDS
2006 db drag WF 3rd place 161.2 SM3-4
2007 db drag WF 1st place 163.4 SM3-4
Loudest to date 165.9 SS3-4 with borrowed equipment
2010,2011 db Drag World Finals judge.
Old 08-30-2012, 04:00 PM
Mr.G6's Avatar
0/11 sssss4614
maybe i mis understood?
are the bolts too long? or just not big enough head
Old 08-30-2012, 04:01 PM
Dunbar91's Avatar
0/11 sssss6816
bolts length is perfectly fine, the bolt head is also fine. The way the bolt holes in the motor line up with the holes in the basket, this positions the bolt towards the back of the hole so 1/2 of the head is on the back side of the basket hole
Old 08-30-2012, 04:04 PM
Dunbar91's Avatar
0/11 sssss6816
Figured washers were my best bet but thought i'd ask for a second opinion
209native's Avatar
0/11 sssss1975
i think someone else misunderstood. im with you that allen head doesnt have much area and it will prolly dig in a bit when you tighten down without them
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 08-30-2012, 04:06 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
small washer and blue threadlocker is what i would do. no ca glue on the bolt.
My game is legit,
0/11 ssssss437
I think having the pressure on one side of the bolt head might be bad i would flatten the basket so the head sits flush on the basket.but thats just me
The Following User Says Thank You to stevew008 For This Useful Post:
dagodpere (08-30-2012)
Old 08-30-2012, 04:09 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
you do realize people dont put CA glue on the NBolt heads right? its a asphalt based glue, like CP Moyen that we use. extra insurance. shit you can drip some in the threaded hole if you want. but yes, add a washer, and why not a locking washer also.
my fellow bassheads..!! xbacardi151 New Member Orientation 1 04-26-2012 04:46 PM
Hello fellow bassheads. penguinslikebass1995 New Member Orientation 27 03-23-2011 07:49 PM
What's up fellow Georgians??!? OneSpiritBrain Georgia SPL 53 11-30-2010 03:22 PM
fellow boxbuilders kingmade08 General Car Audio Discussion & Questions 8 10-13-2009 09:35 AM
Greetings Fellow Audiophiles Gwargar New Member Orientation 22 02-11-2009 10:51 PM
