Vent Mach and WinISD - Car Audio Classifieds!
Old 08-30-2012, 03:55 PM
xnewbx's Avatar
0/11 ssssss985
Default Vent Mach and WinISD
I've been throwing some numbers around in WinISD and after awhile I realized I don't know what type of numbers I should be looking for. The main one is my Vent Mach? What is a good number, most of the numbers I seem to get are .01... I doubt that's good but I'm just curious.
If I read my WinISD correct, it should play from 29 to 58 Hz? With a 30 dB gain at 42Hz? I believe i'm lost.
and I doubt this is good lol, but please tell me what I should do if it's not good, or just some pointers
Old 08-30-2012, 04:13 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
MACH is the speed of sound in moving air. The spec refers to the air "speed" or "velocity" in the vent. Welocity higher than 0.10 MACH at full power will have audible port noise no doubt about that...
Keep this in mind, MACH will vary on power and how much air your driver will displace. At tuning frequency it is the highest.
What Driver are you using and what size is the box? and port?
Old 08-30-2012, 04:17 PM
xnewbx's Avatar
0/11 ssssss985
So when you say higher do you mean like .11 , .15 , .2?
Old 08-30-2012, 04:22 PM
DonH's Avatar
0/11 sssss6645
yes, .11 is a greater number than .10 lol
Old 08-30-2012, 04:32 PM
xnewbx's Avatar
0/11 ssssss985
Ok well on a side question, what is the Pe, Le, Z, and Sd? My sheet with my T/S parameters does not have this information?
Old 08-30-2012, 04:44 PM
DonH's Avatar
0/11 sssss6645
chk the link brah
http://www.the12volt.com/caraudio/thiele.asp
Z is the nominal impedance of the driver.
The Following User Says Thank You to DonH For This Useful Post:
xnewbx (08-30-2012)
Old 08-30-2012, 05:07 PM
xnewbx's Avatar
0/11 ssssss985
Alright well if this 'general' design looks good from just the picture I'm going to go ahead and build it. I'm not trying to get HACK accurate, but trying to just get something that should work from the charts and knowledge alone.
Old 08-30-2012, 05:24 PM
Micksh's Avatar
0/11 sssss2596
Make sure when you input all the enclosure info you are inputting the power you are running...otherwise the vent mach won't show up correctly on the graph.
My Youtube page
Astro build log link
Old 08-30-2012, 05:38 PM
xnewbx's Avatar
0/11 ssssss985
Do I change that in the plot bar? Because no matter what I input the mach is always the same.
Old 08-30-2012, 05:44 PM
Micksh's Avatar
0/11 sssss2596
Under the "signal" tab in the part that shows all the box/port info, there is a "system power" place to input it.
My Youtube page
winisd vent mach accuracy. jt_buck Enclosure Discussion & Design Construction Help 68 06-07-2011 11:53 PM
Gotta vent a little.... Mgcauctions09 (Second Skin) 23 04-29-2010 02:03 PM
I need to vent guys.. grimreper912003 Off Topic Chat 27 10-29-2009 01:09 PM
Just need 2 vent 225HONDABOY Off Topic Chat 13 10-07-2009 03:52 PM
so i need to vent... brtnboarder3241 Uncensored Off Topic 38 05-21-2009 09:42 AM
