dual batteries - big 3 - now truck won't start - Car Audio Classifieds!
Old 08-31-2012, 12:01 AM
arejayeye's Avatar
0/11 ssssss317
Default dual batteries - big 3 - now truck won't start
I just finished my dual battery setup and upgraded big 3. Now my truck won't start. I jumped it off and drove around for a lil while and still won't start back up. Any ideas? Thanks!
The Following User Says Thank You to arejayeye For This Useful Post:
two18s (08-31-2012)
Old 08-31-2012, 12:09 AM
Austin175's Avatar
0/11 sssss4224
Dude I crap you not I just had went through this yesterday. When you were hooking everything back up did anything touch metal and spark? Have you checked the voltage on both batteries? Are the batteries good?
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 08-31-2012, 12:20 AM
arejayeye's Avatar
0/11 ssssss317
Yea the batteries are good. I just bought both of them. Nothing touched metal. Everything looks fine. I dont understand wat the hell is wrong. I guess I am gonna get my alternator checked out tomor
Old 08-31-2012, 12:56 AM
Austin175's Avatar
0/11 sssss4224
Have you tried starting the truck with the just the under hood batt hooked up.
(caco),
Old 08-31-2012, 01:06 AM
What did you voltage look like when you were driving around with the new battery?
Old 08-31-2012, 03:18 AM
0/11 ssssss227
Check your under the hood fuses. This happened to me as well. You might need to pull them out one by one to be 100% sure as I couldnt tell from a quick glance the first time around until my buddy and I pulled them each individually.
Old 08-31-2012, 03:27 AM
0/11 sssss3986
check charging voltage.
Old 08-31-2012, 03:37 AM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
Nothing to add except check to make sure your starter cable is connected properly
Team XS Power
Team Heavy Hertz
Build-
youtube-
Old 08-31-2012, 03:43 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
corrosion on a starter cable terminal can cause a weak connection not allowing your vehicle to turn over on its own.
Current Build:
#60sHereIcome
Old 08-31-2012, 09:52 AM
arejayeye's Avatar
0/11 ssssss317
Starting battery is showing 12.3 and aux battery is showing 12.7. When I upgraded all the cables, I didn't replace the cable running from my positive starting battery to the fuse box. It looks like its 8ga. Should I replace it with 0ga also?
DC98hoe (09-01-2012)
2 alts and small batteries or 1 alt and big batteries? doug118 General Car Audio Discussion & Questions 17 01-24-2012 09:25 PM
hu keep reseting every time i start my truck pokerchip11 General Car Audio Discussion & Questions 2 03-08-2011 04:10 PM
