To use a Dist block or not - Car Audio Classifieds!
Old 08-31-2012, 04:59 PM
0/11 ssssss320
Default To use a Dist block or not
ok so i finally bought a 4 channel skar amp and am wondering how i should wiire the power i have 0 gauge running from my battery under my hood straiight into my skar 1500 im curious as to can i add a distiibution block 0 gauge input to 0 gauge output on that set up for the amps so id run it to the trunk then connect my skar 1500 and skar 85 to it is that safe or should i just run a 4 gauge wiire from my battery up front back to the trunk ?
Old 08-31-2012, 05:09 PM
mcmuffin's Avatar
0/11 sssss3380
anl fuse holder if what ive done. its alot easier. 1/0 into 1 end then 4 ga and 1/0 from the other end
*** NEW BUILD COMING SOON ***
its a secret for now
Old 08-31-2012, 06:46 PM
0/11 ssssss320
Not sure what that looks like can you send a pic
Old 08-31-2012, 06:58 PM
0/11 sssssss80
just google anl fuse holder.
Old 08-31-2012, 11:05 PM
0/11 ssssss320
yea i know what that is but im asking to add my 4 channel amp should i run a 4 gauge from the battery for power or can i use a distribution block to power my 4 channel and skar 1500 they would be connected to 0 gauge power wire from the battery
Old 09-01-2012, 01:13 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
yes you can
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 09-01-2012, 01:35 AM
0/11 ssssss386
Should be fine with dist block and 0 gauge input, that wire will handle like 400 or 500 amps of currrent. Unless you are gonna do more power later on your subs?
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 09-01-2012, 02:11 AM
Wes669's Avatar
Street light banger
0/11 sssss1869
Ya dude google anal fuse for a few pics!
'02 trailblazer
4 c2 threatcon 2 12s
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 09-01-2012, 02:36 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
whatever is cheaper and or safer
idiot.
Current Build:
#60sHereIcome
Old 09-01-2012, 09:05 AM
0/11 sssss1868
Easier to run the distrobution block, honestly. Then again, if you want to do a whole additional run, go for it. Personally, I've had my Kicker distros for quite some time, and I don't see them going anywhere until I add a secondary battery... no need for them then.
voltage drop melted my dist block biglion General Car Audio Discussion & Questions 23 08-18-2012 01:31 PM
WTB O gauge ANL dist block SPLpizzaguy Wanting to Buy (WTB) 8 04-28-2011 08:37 AM
price quote on dist block(s) dbjunkies (Tool Maker) 0 03-24-2011 03:54 PM
dist block(1)1/0 to (4) 2gauge.. $18 plus shipping {bargain} iamsonic Bargain Bin 0 12-14-2009 11:45 PM
F/S - Kicker FDBA (Fuse Holder / Dist Block) thedukey42 Wiring, Electrical & Other Installation Equipment 0 06-26-2009 08:28 AM
