street stock spl,ports 1 or 2???? - Car Audio Classifieds!
Old 08-31-2012, 06:14 PM
0/11 ssssss437
Default street stock spl,ports 1 or 2????
so my new build did a 140.2 with 2 15's and 719 watts sealed on the dash. is that any good?
tuning needs to be 53hrtz because its likes 60 on the mic. should i go with 1 8" 6" long or 2 6"-12" long both will be made from plywood flared style.both setups will be tuned the same. it is subs up,external port back confg.
Old 08-31-2012, 06:31 PM
0/11 ssssss577
math + testing= your answer
anything else is a "suggestion" or "opinion" and can vary.
Old 08-31-2012, 06:39 PM
0/11 ssssss437
yeah i just needed an idea where to start when i port my box.
Old 08-31-2012, 07:10 PM
0/11 ssssss577
i would use one( just imo ) and play with port length untill you find the sweet spot , start with way more port then you need then test untill its perfect
Old 08-31-2012, 08:04 PM
0/11 ssssss437
yeah i hate building mdf ports.maybe ill get some crete tubes and just test with them first then build the real deal.
Dd m2b...perfect street stock amp jws84_02 Mono Amplifiers 16 02-22-2013 02:42 PM
2 - NSv2 15's in a Outback - dB Drag Street Stock Run Anton Miller (Sundown Audio) 38 09-01-2012 11:09 PM
need suggestions for street stock subs?? blazin20s General Car Audio Discussion & Questions 24 11-03-2011 09:37 PM
street stock needs more ppl Arizona Kid Competition Corner 10 01-22-2011 12:26 AM
2010 dB Drag Street Stock Rules Clarifications Jeremy Weber General Car Audio Discussion & Questions 36 07-13-2010 02:10 PM
