What Final Ohm Load Should I run - Car Audio Classifieds!
Old 09-01-2012, 10:21 AM
0/11 ssssss106
Default What Final Ohm Load Should I run
I'm running two Zv3's 12" off a sundown SAZ3500.
for electrical I have a mechman 320 and 155 ah in battery (shuriken bt-80, bt-35, bt20, bt20)
idk if I should run D1's at 1ohm.
or
D2's run them at 2 ohms daily then .5 for comps/demos?
Old 09-01-2012, 10:24 AM
4ozgloves's Avatar
0/11 ssssss309
You should be fine at .5 daily
Old 09-01-2012, 10:25 AM
0/11 ssssss106
Thanks man! I know alot of ppl are against running .5 but I think I have the electrical to back it up
Old 09-01-2012, 10:27 AM
Alek17's Avatar
0/11 ssssss360
I ran my saz3000d at .5 all day long and the only electrical i had backing it up was a 1700 battery. Amp never got hot or anything. Love the sundown amps.
Old 09-01-2012, 10:31 AM
0/11 ssssss106
awesome good to know! Thank again guys
Old 09-01-2012, 10:34 AM
Mr.G6's Avatar
0/11 sssss4614
just bc your wired at .5ohm doesnt really mean anything.. you will always have impedance rise and such
you should be fine at .5ohm maybe at most add another small battery
2000 Gmc Sonoma ext cab
Old 09-01-2012, 10:36 AM
0/11 ssssss106
That's also what I figured, even though impedance raise is wild on music. It would be nice to stay around 1 ohms on a 38hz test tone after box raise. (38's where I peak)
Old 09-01-2012, 02:49 PM
LoudnProud's Avatar
0/11 ssssss992
Like everyone else has said. With box rise and voltage drop you wont be anywhere close to .5 reactive. Should be nice. Good luck man.
Old 09-01-2012, 03:17 PM
mega fatty
0/11 sssss6008
Run it at .5 watch your voltage and if it starts dropping too low turn it down
I run my D9 at .5ohm with 2 spv70's with a stock alt never clamped it but it's loud and drops to about 12.5 for most songs
You can wire that amp at .5 and only pull 1000watts outa it and keep it cool, it's just when youre reaching the limits of your amp that .5ohm will really stress it more and possibly damage the amp(as long as it is capable of running .5ohm)
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-01-2012, 03:18 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
i ran two DC XL 15's on a saz-2500 @ .5ohm daily for a few months, never had any issues. i had a singer 275amp alt, 2 d3400's and the big 3 done. amp never even got warm really.
PLEASE HELP Crossover, Final ohm Load, Bass Blocker nwdsk8er General Car Audio Discussion & Questions 7 11-25-2011 07:21 AM
How do I figure final (ohm) load on Amplifier? Jdubs04ss General Car Audio Discussion & Questions 15 04-20-2011 02:31 PM
whats my final ohm load??? [email protected] General Car Audio Discussion & Questions 7 03-04-2011 04:21 PM
how to get final load of 2 ohm? dylan9999 General Car Audio Discussion & Questions 10 08-31-2010 04:46 PM
WTB: 2 10" Subs ~Final 1ohm load of 700~800watts~ revrider1 Wanting to Buy (WTB) 6 05-23-2010 11:36 AM
