Multiple small batteries vs. Large batteries - Car Audio Classifieds!
Old 09-01-2012, 01:23 PM
thawaxshop's Avatar
0/11 sssss2506
Feedback Score: 48 reviews
Default Multiple small batteries vs. Large batteries
I've been debating this for a lil while and want to ask pros and cons of running multiple smaller batts over single larger ones. In my case I can either fit 3 XS XP3000 or 9 XS XP950's. Prices are pretty close as well as AH. I want to feed a 5-6k amp
Sent from my Galaxy Nexus using Tapatalk 2
Old 09-01-2012, 01:25 PM
Jokerr's Avatar
0/11 sssss2279
Feedback Score: 33 reviews
More small batteries are better according to a thread by xs power in here somewhere
I buy blown amps,
Old 09-01-2012, 01:26 PM
massivespl's Avatar
0/11 sssss8409
interesting
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-01-2012, 01:29 PM
thawaxshop's Avatar
0/11 sssss2506
I've read things like that just wanted info from people I trust. Something to do with discharge I believe
Old 09-01-2012, 02:02 PM
SPL Distribution Owner
0/11 sssss2983
When comparing a multitude of smaller batteries to larger batteries and the point of being equal is price or especially weight, these are the typical differences-
Not every time but if there a difference, the aH and reserve capacity of a small quantity of large batteries will usually be greater than a lot of smaller batteries. However, the capacity difference may not be that crucial of a difference even by up to 25%.
By me saying this, i would also say that CCA and CA would also be greater from a small quantity of larger batteries because of the duration.
However, when it comes to 5sec discharge, it's very possible that a bank of smaller batts would excel in less voltage drop over a smaller large case battery bank.
I can practically guarantee with certainty (minus batcap 8400 \ 8400extreme) that when comparing like battery lines in terms of weight capacity, that the smaller bank will have incredible amount of discharge capability.
Example-
Odyssey PC1200 vs PC2150
PC1200 has 1200A for 5sec, 42aH, 38lbs $222
PC2150 has 2150A for 5sec, 100aH, 78lbs $377
10 PC1200s = $2220, 12000A for 5 sec, 420aH, 380lbs
6 PC2150s- $2262, 12900A for 5 sec, 600aH, 468lbs
In this example, same price, 5sec discharge equal, aH big difference and 90lb weight difference.
The Following User Says Thank You to shizzzon For This Useful Post:
SINTORMAN (09-01-2012)
Old 09-01-2012, 05:08 PM
thawaxshop's Avatar
0/11 sssss2506
So a bigger bank of smaller batts would be better for burping. So a large bank would be better for daily?
Old 09-01-2012, 05:31 PM
0/11 sssss2983
If we are to compare the most absolute best scenario, then yes, you would probably be right.
This is also probably why the XP series exists too.
The XP line doesn't have as high a quick discharge capability as the D series does but can hold up to longevity better.
In terms of measurable difference though.. that I couldn't answer.
Measurable difference is key though to everything.
It may only differ by as little as 0.3v initial voltage drop.. I do not know.
Something I do know is adhere to manufacturer's recommendations regardless of quantity and as long as properly followed, you will not be disappointed.
Old 09-01-2012, 06:32 PM
thawaxshop's Avatar
0/11 sssss2506
Just trying to figure out the best set up for me lol
Old 09-01-2012, 06:46 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
another thing is you might see better voltage just because of more terminals and less resistance. I know the difference would be minimal but it could be a .1db since you have more terminals vs battery power with more smaller batteries opposed to less bigger batteries.
Although another thing to consider is more batteries the higher chance of some failing from "natural" reasons. Just because you are running more batteries. Again.. not that important but something to think about.
Current Build:
#60sHereIcome
Old 09-01-2012, 06:48 PM
0/11 sssss2983
For daily, the stress of determining the best brand, product line, etc is less hectic because
Music is dynamic. However, I would still stick to trusted car audio specific agm batteries.
The goal for daily batteries mainly comes down to price, but if you ever want to compete, i'd stick with proven performance brands. Also, it's typical that higher priced agm batteries have a much longer cycle life!
Remember that.
HowTo: Wire Multiple Batteries lxl r00k lxl Tutorials & Quick References 64 06-19-2012 05:34 PM
2 alts and small batteries or 1 alt and big batteries? doug118 General Car Audio Discussion & Questions 17 01-24-2012 09:25 PM
Wiring multiple batteries mrtopnotch561 General Car Audio Discussion & Questions 11 09-09-2011 12:12 AM
wiring multiple batteries mrtopnotch561 General Car Audio Discussion & Questions 2 06-16-2011 11:57 AM
WTB multiple batteries. chunt33 Wanting to Buy (WTB) 0 04-26-2011 08:46 PM
