Someone want to help me with mids and highs? - Car Audio Classifieds!
Old 09-01-2012, 10:34 PM
0/11 ssssss658
Default Someone want to help me with mids and highs?
Well i've been into bass for a few years now and I love it but it is time for some mids and highs. I've gone through a few subwoofer set ups but never messed with mids and highs. My question is, how would I wire 2 Crescendo PWX-10s and 4 Crescendo FT1 super tweets to a Kicker 800.4? I'm going to need a crossover as this amp isn't able to run active. But do I just run a set of wires from amp to crossover then wire to certain ohm loads from the crossover to speaker? Just don't want to mess anything up.
I disagree.
To me, motivation comes when the fear of staying the same is greater than the fear of change.
Old 09-01-2012, 10:42 PM
0/11 ssss31256
buy a two way crossover to separate the tweeter signal from the mids.
run the mids on one set of channels.
run the tweeters on the other set of channels.
hopefully your deck has highpass to take care of the bottom side of the mids.
Old 09-01-2012, 10:46 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
first read up on active vs passive filtering.
Then chosoe one of the two.
Passive you need to make or buy crossovers.
Active, use a 2-band eq or use a digital sound processor.
Old 09-02-2012, 03:22 AM
Beerdrnkr's Avatar
0/11 sssss1231
2-band eq? To run active u need an active capable hu, external active crossover, active capable amp, or a processor.
Just get an external 2 way xover. Run ur hu high pass filter to 63-80hz or so, set the amp at around the same as well as the external xover or if it has a high low pass u can bandpass the mids and run the tweets on the high pass of the external xover.
Sent from my ADR6300 using Tapatalk 2
mids and highs 1LOUDYUKON General Car Audio Discussion & Questions 2 10-30-2011 04:51 PM
A little help with mids and highs... RWatts General Car Audio Discussion & Questions 3 08-01-2011 08:23 PM
mids and highs burd337 General Car Audio Discussion & Questions 1 07-31-2011 05:27 PM
Highs and mids? mads10bass General Car Audio Discussion & Questions 10 10-06-2010 05:22 AM
mids and highs natisfynest General Car Audio Discussion & Questions 16 01-23-2009 11:47 AM
