Mixing batteries - Car Audio Classifieds!
Old 09-02-2012, 12:07 AM
0/11 ssssss174
Default Mixing batteries
is this ok to do?
i.e. 2 optima blue tops and 4 hawker batteries in my battery bay.
Old 09-02-2012, 04:56 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Mixing different brand batteries of the same type is fine.
Resting voltage and self discharge rate is the concern here. Different batt types have different values of each. For example, AGM batts rest higher and self discharge more slowly than wet cells.
Temporarily in a daily driver, it's not a HUGE concern. But over time, it could be an issue.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 09-02-2012, 07:15 AM
Mr.G6's Avatar
0/11 sssss4614
mixing wetcells and agm in time will cause the agm's life to be shorter
bc usually wetcells rest at 12.4 12.5ish and a good agm battery will rest at 12.7 plus (my xs power's rest at 12.9) parasitic draw ill shorten its life in time
but usually agm with agm is ok
2000 Gmc Sonoma ext cab
mixing batteries Pauliesnite93 General Car Audio Discussion & Questions 7 12-01-2010 06:50 PM
Mixing batteries ? Tkelly General Car Audio Discussion & Questions 15 08-22-2010 08:06 PM
Mixing batteries??? RetroAudioInc General Car Audio Discussion & Questions 5 10-14-2009 11:59 PM
Mixing Sub Amps dropped_tb General Car Audio Discussion & Questions 13 09-30-2009 07:08 PM
Mixing wet batteries, and Dry batteries. hornedfrog1985 General Car Audio Discussion & Questions 0 09-22-2009 08:49 PM
