More inverted Qs - Car Audio Classifieds!
Old 09-02-2012, 11:12 AM
xnewbx's Avatar
0/11 ssssss985
Default More inverted Qs
1. I've heard/read that when inverting multiple subs that as long as they're all inverted you don't need to worry about flipping the phase/ -/+
2. Will the mounting holes be the same because they seem to be extremely close to rubbing the side of the woofer.
3. Will the bolts hold the woofer alone? If I'm looking at it right the basket won't be helping at all and all the weight will be on the bolts... Because I see most inverted subs sitting on top of the box, while these will be on the side.
Old 09-02-2012, 11:21 AM
0/11 ssss31255
If they are all the same, polarity can be the same on all woofers.
I suggest inverting the polarity on all inverted woofers so the sound is "in phase" with the mids and highs.
but many times, reversing the phase makes it sound better.. so it's up to you.
You'll need to measure the ID of the gasket and make your cut out that size. {ID of the front of the gasket}
they might hold. it depends on the weight of the speaker, what "bolts" are used and the style of basket.
inverted sub hole. jalm919 (Sundown Audio) 16 06-21-2012 11:31 AM
Inverted subs nuboot General Car Audio Discussion & Questions 4 05-12-2012 08:13 PM
Firing 2 regular and 2 inverted vince79vette General Car Audio Discussion & Questions 3 02-01-2012 09:11 AM
Inverted subs? Ajax_6154 General Car Audio Discussion & Questions 26 08-13-2011 09:56 AM
Inverted vs Regular mounting of a sub... grocerygetter General Car Audio Discussion & Questions 14 07-07-2011 10:34 PM
