Wire thats hot only when engine is running - Car Audio Classifieds!
Old 09-02-2012, 12:11 PM
arejayeye's Avatar
0/11 ssssss317
Default Wire thats hot only when engine is running
I have went through the truck with a test light and every wire I have come across is hot in both acc and run. I need a wire that is only hot while engine is running / not acc. Vehicle is a 2000 chevy k2500. Anybody happen to know of one?
Old 09-02-2012, 02:57 PM
xnewbx's Avatar
0/11 ssssss985
Well your remote turn on from you head unit, accessory cables that can be found on Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers or
Vehicle wiring diagrams. Unless I'm reading this wrong you're trying to hook something up to turn on when you start your car?
Old 09-02-2012, 03:13 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
From what I read he just wants it on when the car is running, not when it's in acc mode. That means the head unit wire won't work.
You should check this:
1999 Chevrolet C/K Pickup Alarm, Remote Starter, Keyless Entry Wiring Information
It's for a 99, but it might still apply. The starter wire might be what you want.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 09-02-2012, 03:30 PM
arejayeye's Avatar
0/11 ssssss317
Yea, i need a wire only hot while running and not in acc. I will check the link, thanks
Old 09-02-2012, 03:31 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
why not setup your own switch?
Old 09-02-2012, 03:35 PM
0/11 ssssss226
Could use a latching relay or something along those lines thats turned on when it sees voltage on the starter wire problem is the starter wire only has voltage on it in the start position. More detail on what you are trying to do would be nice.
other wise your next best bet would be using one of the ignition wires as they dont drop out when you go to start like an ACC wire does..
Old 09-02-2012, 03:43 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
the starter wire youre reffering to is a momentary on,
spring loaded.
i believe that would be getting close to his ecm, the ignition wire trick, the latter
id say put a manual switch from the accy circuit, or something similar
Old 09-02-2012, 04:00 PM
Mr.G6's Avatar
0/11 sssss4614
why not just run a hot lead and put it on a switch?
example..with my new daily beater all the wiring was basically shot
so i ran a switch to power the cig lighter and the radar detector.. and another switch to turn the radiator fan off n on.. I HATE it when ppl just hack shit up lol
2000 Gmc Sonoma ext cab
Old 09-02-2012, 05:51 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I would assume this is for an alt? Look under the hood. There should be a circut only on while the vehicle is running.
Old 09-04-2012, 03:02 PM
Benny33's Avatar
Hockey players, man...
0/11 sssss1616
In the main ignition harness under the dash there should be two different accessory wires. One is hot when the ignition is in the "on" and in the "run" position (like the radio) and the other will only be hot when in the "run" position (like the heat/ac blower). HOWEVER, be very careful when looking for these in the ignition harness. Test lights make airbags pop!
Yous just figures that out? All the hots ones is crazy!...And deh ugly ones too. - Toki Wartooth
Car running cold? Container for engine coolant(antifreeze)? its_ray_ray General Automotive Chat 13 08-28-2011 07:52 AM
amps running hot while not being played. mrfantastic911 General Car Audio Discussion & Questions 7 07-08-2011 07:43 PM
Amps running hot and acting funny - any ideas? Silenkiller General Car Audio Discussion & Questions 18 05-26-2011 05:49 PM
Amps running hot, for no apparent reason. jt_buck General Car Audio Discussion & Questions 12 05-12-2011 02:22 PM
Cactus Elite 12k running hot loud avalanche General Car Audio Discussion & Questions 150 07-22-2010 01:39 PM
