subs moving with idle - Car Audio Classifieds!
Old 09-02-2012, 10:06 PM
Active Member
0/11 ssssss546
Default subs moving with idle
Has anyone here ever troubleshot subs moving with engine idle? I recently got rid of my line driver/eq which was cutting in and out. I am running a sundown 3k which was just repaired and it is wired to 1ohm load. I never had this issue before and was hoping somebody else has. My electrical is setup with 2 runs of 2/0 for power front to back, three runs of 2/0 to the frame, with big three in 2/0 up front. There is no engine whine through mids or tweets.
Is it an amp issue or a grounding issue? How would I tell the difference? Thank you for any help.
03' Mercury Mountaineer XR
Kenwood DDX719/ 2 sets ID CTX CS 6.5's/ Sundown SAX 200.4
4 x 15" Crossfire XSv2's/ 2 x Crossfire XS 8k's
Mechman 340a alt/ Transpo ext. reg./9 x XS 3100's/ SHOK Industries wire.
TEAM CROSSFIRE/TEAM NWSPL/TEAM SHOK
155.5 @37hz sealed on the dash and gaining
Old 09-03-2012, 12:41 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
If it is doing it without the rca's plugged in then something is wrong with the amp/ amp wiring. If it isn't then the problem is with your HU or HU wiring.
Current Build:
#60sHereIcome
Old 09-03-2012, 12:51 AM
Active Member
0/11 ssssss546
Thanks. I pulled the head unit and played with it while running. The RCA's may be the issue. They are new so I didn't think of them at first. I can push on the RCA at the sub input and make it start and stop the idle bumping. The sub out is a cord separated from th head unit, where as the front and rear are on the head unit if you know what I mean. This is the HU in my sig. I will try running a new RCA cable tomorrow. I have also blown the pico fuse or whatever folks call it when installing new 6.5's in the doors. I now have the speaker RCA's grounded to the hu frame which eliminated the noise I got when that happened. If the new RCA does not solve it, I may try grounding the sub out RCA shield to the hu frame too.
Old 09-03-2012, 12:52 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
try running ur ground back up to the front batt instead of grounded to frame
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 09-03-2012, 12:53 AM
SINTORMAN's Avatar
0/11 sssss4907
Yeah its either the rca or you need to ground the shield since it is a seperate unit.
Also.. you don't have your rca's ran next to power wires right? That could cause interference.
Current Build:
#60sHereIcome
The Following User Says Thank You to SINTORMAN For This Useful Post:
RRR37 (09-03-2012)
Old 09-03-2012, 12:58 AM
Active Member
0/11 ssssss546
No, the RCA's are on the opposite side of the car. I have run any different amps and never had this issue, but was always through the eq. The more I think about it, it sounds like feedback because I need to ground that shield as I did with the front and rear channels
Old 09-03-2012, 01:07 AM
SINTORMAN's Avatar
0/11 sssss4907
How late is it there lol? I would just go try it real quick so you know if that fixed the problem.
Current Build:
#60sHereIcome
Old 09-03-2012, 01:15 AM
Active Member
0/11 ssssss546
Nah, car is in the garage and I'm chillin inside about to watch some breaking bad. I'm in no hurry tonight, tomorrow is a day off, got all day to mess with it. I get a one track mind sometimes working on my car, next thing I know it will be 4am and the wife will at the garage door asking why the hell I'm not in bed. Thanks for your help.
Old 09-04-2012, 02:33 PM
Active Member
0/11 ssssss546
Thanks for the help guys. Just for future reference if anyone searches and sees this topic. It was the RCA's. Even though they were new, they were bad.
Adjustable idle for $1.99 TaylorFade Tutorials & Quick References 34 01-04-2012 08:56 AM
up my idle? Nd_6037 General Automotive Chat 19 09-18-2010 08:19 PM
subs arent moving! Vince6o1 General Car Audio Discussion & Questions 41 07-22-2010 06:41 AM
Subs aint Moving WTFF!! GetLikeMe General Car Audio Discussion & Questions 37 05-27-2010 09:39 PM
Need more idle output on a budget??? MECHMAN General Car Audio Discussion & Questions 15 06-24-2009 06:47 PM
