Opinions on this alternator - pics inside - Car Audio Classifieds!
Old 09-02-2012, 10:48 PM
arejayeye's Avatar
0/11 ssssss317
Default Opinions on this alternator - pics inside
I am looking into replacing my stock alternator in my Chevy K2500. I have this 200 amp Stinger alternator that I picked up off Craigslist a while back. Has anybody used one of these? I am trying to decide if I should use this or buy a bigger one. Currently my amps are Memphis MC1.1500 and MC4.125, Red Top starting batt and Yellow Top aux batt w/ Big 3 done
Old 09-02-2012, 10:53 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
give it a shot.. u already got it so u minus well put it to use. but u shouldnt need a HO alt with that little bit of power. u only got about 1600 or so true rms there
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 09-03-2012, 12:28 AM
arejayeye's Avatar
0/11 ssssss317
I plan on steppin up to about 3-4K in the near future
Old 09-03-2012, 12:32 AM
0/11 ssssss855
i would throw it on there before buying another you can always add more batts later also worst comes to worst just go to a bigger one if you have a major volt drop
Old 09-03-2012, 12:40 AM
arejayeye's Avatar
0/11 ssssss317
The pulley on the stinger alt is smaller than my stock pulley. Should I swap pulleys or get a new belt?
Old 09-03-2012, 12:44 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I'd run it with the stock pulley put on it. See what happens.
Might have it bench tested at autozone or the such to make sure there is nothing wrong with it first.
Team CACO Team SHOK
Supporting Member
Old 09-03-2012, 01:38 AM
Ronmeister's Avatar
0/11 ssssss791
You'd want the smaller pulley, so it turns faster so it's able to produce at least a bit of current while the engine is turning only smaller amounts of RPMs...
Just get 'er load tested as is too, with the smaller pulley.
Old 09-03-2012, 10:15 PM
arejayeye's Avatar
0/11 ssssss317
I had the alt tested and it looked good so I put it on this evening with the smaller pulley that came on it. Driving around voltage is between 14.1-14.4. When I turn volume up pretty good voltage is dropping to low 13s and lowest I saw was 12.9 a few times. I was really hoping to see voltage staying close to 14
Old 09-03-2012, 10:27 PM
TEAMWOOFERS & TEAMXPLICIT
0/11 sssss3841
Feedback Score: 22 reviews
^^:agreed: Singer alts are supposed to achieve higher amperage at lower rpms then most alts. That's a way to make it generate faster is smaller pulley.
Singer from what I here are great alts. I've talked to mr.singer and he's a really good guy. If you talk to him I sure he'll help you decide whether to go higher or if your good.
wow, i really wasnt expecting that many people to pick ed over jacob? with the way people jock sundown around here
[email protected]
Old 09-03-2012, 10:33 PM
0/11 sssss1380
Originally Posted by MrRTJ24 View Post
^^:agreed: Stinger alts are supposed to achieve higher amperage at lower rpms then most alts. That's a way to make it generate faster is smaller pulley.
Stinger from what I here are great alts. I've talked to mr.stinger and he's a really good guy. If you talk to him I sure he'll help you decide whether to go higher or if your good.
i think your getting SINGER and stinger mixed up
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
DD Z SE broken (pics inside) 99Bonney General Car Audio Discussion & Questions 59 02-14-2012 10:24 AM
Well i have another new amp (pics inside mattintc10 General Car Audio Discussion & Questions 11 04-10-2011 09:23 PM
Painted my rims (pics inside) Jh8909 General Automotive Chat 7 04-10-2010 11:51 AM
New Subs for Me, PiCs InSidE sdelthon Member Rides & System Pictures 31 03-31-2010 10:29 AM
