Digital Multimeter Vs. DD-1 - Car Audio Classifieds!
Old 09-03-2012, 12:01 AM
0/11 ssssss227
Default Digital Multimeter Vs. DD-1
What are the differences of a Digital Multimeter Vs. a DD-1
Old 09-03-2012, 12:04 AM
Matt3824's Avatar
0/11 sssss3754
Could you be a little more specific?
Generally, a DMM read AC/DC Voltage and Amperage and Impedance in Ohms, and a DD-1 checks for distortion at a set frequency.
Old 09-03-2012, 12:06 AM
0/11 ssssss227
What are the different uses of a Digital Multimeter vs a DD-1. You can't use the Multimeter to check for distortion, but you can use it to set gains? Isn't that what the DD-1 is used for is gains also?
Old 09-03-2012, 12:14 AM
Me > Lord Van
0/11 sssss2831
A DMM does WAY more things that a DD-1 can do. The DD-1 is a specific tool.
Most common car audio uses for a DMM is checking voltage (AC and DC) and checking ohm loads. It can also be used to set gains and is used to clamp (see what kind of power it's making) amps, in part with a clamp meter.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Clamp Multimeter FS/FT joe*89 Wiring, Electrical & Other Installation Equipment 17 10-08-2011 02:33 PM
Multimeter andrue General Car Audio Discussion & Questions 3 05-04-2011 03:43 PM
How to use Multimeter..... vicon4z General Car Audio Discussion & Questions 12 04-21-2010 06:18 PM
testing a sub with a digital multimeter michael707 General Car Audio Discussion & Questions 26 11-01-2009 12:25 AM
[SOLD] Digital Multimeter (New) MHD2000 Miscellaneous Stuff For Sale 6 07-17-2009 07:42 PM
