Solenoid question - Car Audio Classifieds!
Old 09-03-2012, 12:37 AM
0/11 sssss3986
Default Solenoid question
http://www.alumapro.com/docs/cap5wiring.pdf
the cap i have is hooked up just like this but the cap only has 4awg output/inputs. my amp has 3 1/0 inputs. does a solenoid allow power to pass power both dirrection through the solenoid? i was thinking about running wires off the same size of the solenoid that the power from the battery goes too. use the post as a distro. would it work that way?
Old 09-03-2012, 12:41 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Team CACO Team SHOK
Supporting Member
Old 09-03-2012, 12:43 AM
0/11 sssss3986
? im serious. never wired up a solenoid before. i picked up this cap off craiglist this past week. allowed 5 farads in my class and i said why not give it a shot. .1 db is .1 is i gain.
Old 09-03-2012, 12:46 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
You're stacking ring terminals....... Why wouldn't that work?
I don't understand the reasoning behind using a solenoid anyways.
Team CACO Team SHOK
Supporting Member
Old 09-03-2012, 01:02 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
SMH
Current Build:
#60sHereIcome
Old 09-03-2012, 01:09 AM
0/11 sssss3986
yah i dunno why they came with one either. i guess the way they are they constantly draw power or something.
Old 09-03-2012, 02:46 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Caps should only draw power until they are charged (doesn't take a very long time) and that's it.
But yeah a solenoid is a direct connection with no diodes and stacking rings is direct connections so it's like a bolt between all the wires when it's on.
No worries anywhere, just hook everything up all willy nilly like and have a blast.
Team CACO Team SHOK
Supporting Member
Old 09-03-2012, 08:02 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Solinids are only rated for so much amperage so make sure its rated for what you are doing. But you don't have to use the outputs for the amp. Run all your 1/0 just like you would without the cap. Then run the leads from the cap to the amp inputs. You may have to strip some wire back to get it all to fit. But it should work. And honestly the solinoid isn't needed.
probably a dumb question but quick question about pollyfill mattintc10 General Car Audio Discussion & Questions 15 05-05-2012 04:46 PM
BNIB Trunk/Door Pop Solenoid Kit (x2) toolguy420 Wiring, Electrical & Other Installation Equipment 44 03-28-2011 11:31 AM
where can i find this type of solenoid? maxspl153 General Car Audio Discussion & Questions 4 03-08-2011 03:55 PM
starter solenoid omgitscollin General Car Audio Discussion & Questions 7 02-27-2011 06:17 AM
box question (NOT A DESIGN QUESTION) highpsicobra General Car Audio Discussion & Questions 0 07-15-2010 02:10 AM
