amp voltage - Car Audio Classifieds!
Old 09-03-2012, 03:48 PM
0/11 sssssss42
Default amp voltage
when monitoring your amp voltage what is the best way to hook up, lets say a stinger volt meter to your amp?
Old 09-03-2012, 03:52 PM
schrummy's Avatar
0/11 ssssss288
right in your power leads on the wires... i have 18 awg wire wrapped around my 1/0 wire going into the amp
150 db @ 33hz
Team Midwest
Old 09-03-2012, 04:13 PM
18psi's Avatar
0/11 ssssss500
Power into power, ground into ground and remote to remote ....
I ran remote from battery to a switch to control the bright ass light .
Old 09-03-2012, 04:41 PM
Mr.G6's Avatar
0/11 sssss4614
or if you worried about shoving too many wires into you amp terminals you can hook it to the rear battery if you have one
but directly into amp terminals is best
2000 Gmc Sonoma ext cab
Old 09-03-2012, 10:25 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
Yes like the rest said. Hook it straight to your amp's power and ground. You definitely get a WAY BETTER Voltage reading from there. That's how I have mine hooked up.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 09-03-2012, 11:29 PM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
how accurate is it to be hooked at the amp terminal but mounted at the dash? Does the wire length affect it much from amp to dash?
2 FI bl 18's walled in 2012 scion xb
Old 09-03-2012, 11:37 PM
0/11 ssssss244
If there is any (measurable) difference at all, there are 2 ways to combat it:
1. The drop across the wire is a constant (if it's .1 then it will always be .1). So you could measure it and if your meter was off by .1, you could just keep that in mind and add .1 (mentally) to the reading.
2. Volt meters such as the Stinger are adjustable. So you measure at the amp, then match the voltages using a knob on the back of the meter. Problem solved.
Old 09-03-2012, 11:43 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
yes quite a bit sometimes depending on the gauge wire you use.
Stinger is overrated...
3 Blue LCD Digital Volt Panel Meter DC 20V_DC Volt meter_Panel Meters_Measure Power Adapters_Sure Electronics' Webstore
Shipping takes a little longer but worth it...
Current Build:
#60sHereIcome
Old 09-04-2012, 12:03 AM
98Expo's Avatar
0/11 sssss1929
^^thanks for the link, I was looking for something other than the stinger
Old 09-04-2012, 01:40 AM
TEAMWOOFERS & TEAMXPLICIT
0/11 sssss3841
Feedback Score: 22 reviews
I'm going to be getting one of these soon so It'll be interesting to have one and see how accurate it will be:
http://www.newegg.com/Product/Produc...-pla-_-NA-_-NA
wow, i really wasnt expecting that many people to pick ed over jacob? with the way people jock sundown around here
[email protected]
Voltage drop at amp low? Help me! kz650 General Car Audio Discussion & Questions 25 10-28-2011 11:05 PM
Pre-amp voltage? andrewtexas123 General Car Audio Discussion & Questions 0 10-25-2010 06:08 PM
amp input voltage Fosgate1 General Car Audio Discussion & Questions 6 12-23-2009 12:16 PM
amp/HU voltage gbo559 General Car Audio Discussion & Questions 2 12-12-2009 05:32 PM
pre amp voltage Fosgate1 General Car Audio Discussion & Questions 7 07-15-2009 09:08 PM
