building my 1st amp rack need a lil help - Car Audio Classifieds!
Old 09-04-2012, 11:30 AM
jpsaudio's Avatar
0/11 ssssss229
Default building my 1st amp rack need a lil help
the vid will show what i have so far but i want the amps to kinda give that floating look well just the 2 amps on the bottom any suggestions other than the angle wood pieces i just made..not sure if i want to keep them there.. i want to put some led lights under the amps.
bb2400.1 amp rack for the jpsaudio08 rebuild pt.8 - YouTube
Old 09-04-2012, 12:51 PM
0/11 ssssss499
mock it up on blocks where you want it to "float" look at it from the side and cut a few peices that match the open space under the amp. get some 14-16gauge plate and cut to mount to the feet, but not be seen, and extend under the amp. mount the blocks to the rack, and the plate, and then mount the amp to the plate. you are gonna want to dynamat, or camper tape the plate where the amp sits on it, or it will buzz. top it of with some nice hex socket head "screws" to mount with.
Old 09-04-2012, 02:35 PM
If you just want to raise the amp up a little bit you can use a threaded rod coupler. They're cheap as hell and come in a ton of different sizes. Use a bolt/screw through the back of the panel to attach it and then screw the amp down to the top of it. Like this, but you'll probably just want 1/4" diameter:
1/2 in. Rod Coupling-ZH119 1/2-5 at The Home Depot
edit: BTW, that's a metric shit ton of wood glue, lol.
Old 09-04-2012, 03:31 PM
jpsaudio's Avatar
0/11 ssssss229
i kinda want both bottom amps at an angle..and yes i used a lot of glue... i love glue..lol
1st tme building enclosure/need help bassknocking561 Enclosure Discussion & Design Construction Help 5 07-21-2011 02:33 PM
Hello. 1st post, 1st car, 1st system. 12Artleye New Member Orientation 19 03-05-2010 08:54 PM
Building a power rack F3M4 Sports and Fitness 0 02-26-2010 11:58 PM
possibly building a wall in 1st gen explorer kurrupt General Car Audio Discussion & Questions 3 09-12-2009 05:34 PM
Need Ideas for Amp Rack and Battery Rack! BassikInstincts General Car Audio Discussion & Questions 8 01-15-2009 10:36 AM
