Distortion full tilt on an Alpine? - Car Audio Classifieds!
Old 09-05-2012, 09:50 PM
Kelocyde's Avatar
0/11 ssssss190
Default Distortion full tilt on an Alpine?
Okay so I wired my subs at .5 today from 2 and also disconnected both my processor and line driver.
I've been told by numerous people that alpines put out no distortion at full volume.
Been told to run my subwoofer level at max (+15 in my case), but regardless of that setting, I'm distorting (according to a DD-1 playing 40 hz @ -5 db), regardless of my gain.
Setting my gains with the DD-1, subwoofer level at 1, results in almost no bass. Turning the sub to +15 gives me a little, but they're still barely moving.
If I turn the gain up a little, still way below distortion "by ear", I get some volume, but it's still quieter than when it was wired at 2 ohms, gain similar locations.
Anyone have any suggestions on how I should have my headunit settings?
Oh, I realized I ripped the DD-1 tones as 320kbps AAC off a flash drive; not sure if that will cause distortion.
I'm going to rip them as apple lossless and put them on my ipod but I was under the impression that is converted to a lossy format when sync'd anyways.
old--06 dodge magnum
source: Alpine ida-x305sbt - imprint processing
lows: 6 Dayton Reference HO 10s - Crescendo bc3500
mids: 2 Crescendo PWX6 - Audison SRx2s
highs: 2 Beston RT002a Ribbons - Audison SRx2
Old 09-05-2012, 10:16 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Dd1 the hu through the amp how the manual says. Hu set flat. Amp gain at 0, and all crossovers "open". Use the 0 db tone. Once you find where the hu clips, then set the amp.
Old 09-05-2012, 10:20 PM
0/11 sssss2429
Feedback Score: 46 reviews
My alpine 9805 clips at 28, backed it down to 25 and set my amp gain. Granted I used a scope.
Bass set to zero and sub level to 15.
Old 09-05-2012, 10:30 PM
Kelocyde's Avatar
0/11 ssssss190
Was the first thing we did.
Old 09-05-2012, 10:43 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
idc what the dd-1 says... no HU sounds good at maxed out volume... unless you know exactly what you are doin yadda yadda
whoever told you to run your sub output at +15 is probably....nevermind this is just dumb
my suggestion to you is to set everything flat and tune with your ear... always works for me... when i say flat i mean your EQ on +0.... subout+0 bassboost+0..... bass boost on the amp should be all the way down etcetc.
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
The Following User Says Thank You to skartisu For This Useful Post:
dcollister440 (09-07-2012)
Old 09-05-2012, 10:53 PM
truespartan9584's Avatar
Team Ungodly Powers
0/11 sssss1524
Feedback Score: 50 reviews
my 9886 showed no distortion at full volume with the dd-1 and ive got it at 15 sub level on the hu
Old 09-05-2012, 10:57 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
alpine's should have the sub level all the way up. just them. 9886, 9887, cda-117 can all go full volume without clipping. i'd check polarity and stuff if it's just a lack of output that's concerning you the most
-Youtube Channel
Old 09-05-2012, 10:59 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
Same here with my 9886.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 09-05-2012, 11:00 PM
Team Ungodly Powers
0/11 sssss1524
i think even with the loud setting on it didnt clip. but i cant remember
Old 09-05-2012, 11:11 PM
0/11 sssss2429
Originally Posted by skartisu View Post
whoever told you to run your sub output at +15 is probably....nevermind this is just dumb.
So you have your sub level set to zero, a heavy bass song comes on and you have no adjustment. Yes that is dumb......
25HZ....FULL DEMO TILT.....4 12s and 7000w Skip01 Car Audio Videos 6 05-21-2012 08:15 PM
Alpine CDE-9874 CD/MP3/WMA Receiver with Full Speed iPod connection ivaylonikolov Head Units, Processors & EQs 9 03-16-2012 01:09 AM
Panasonic CQ-C8100U full dot matrix display 6 RCA OUTPUTS 50Wx4 rear aux in TILT FACE thel.t.d.supply Head Units, Processors & EQs 0 08-25-2011 11:20 AM
Full tilt poker andrewtexas123 Off Topic Chat 4 05-22-2010 02:19 PM
Electrical to support a SAZ-3000D for hours at full tilt? Wheres The Butta (Sundown Audio) 29 10-04-2009 12:01 PM
