car audio install help - Car Audio Classifieds!
Old 09-05-2012, 11:08 PM
0/11 ssssss129
Default car audio install help
hello im new to this and im asking for any advice. Heres what my install includes in the front i have a upgraded batt i believe its a 800+ cca battery along w a 250 anl fuse w 0 gauge ran all the way to my trunk and then in my trunk i have a huge 4000 rms battery its a rv batt the guy i had gotten it from had his rd 7500 ran off it and its worked fine i also have 0 gauge ground and another 200 anl fuse coming from that battery and i have the big 3 done also. Heres where idk what to do i have a 15 inch fi btl w everything and soon to get another one im not sure what i need to do to be able to run both i wanna run 2000-2500 clean rms to each but i wanna stay away from getting a new alt ive had people say to put in a 0 gauge power distribution block and run that and also put in another 200 anl fuse parell to the other one in my trunk or should i just get another battery and what kind and what size and also the amp i have is a massive soundstream xxx6500 and the gain is only going to be at 1/4 to half. Any comments or advice please write back or if u want to write me a faster way u can text me at 8104717233 and thank you for all the advice
Josh
Old 09-05-2012, 11:12 PM
0/11 ssssss126
If you're running more than 2000rms, you should get an H/O alt. And you just wire the subs together to run both.
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
if you plan on running 4-5k you either have to get enough batteries to support it or get a h/o alt. i would go the alt route first since they are cheaper than a bunch of batteries.
My game is legit,
Old 09-05-2012, 11:20 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
you need both... alternator and batteries
they have 2 difference jobs...... if you had 1500rms it would be a different story
if your new to this with that kind of equipment.... research and forums like this are your bestfriend
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 09-06-2012, 12:18 AM
0/11 ssssss129
Well I've had 2 12s that were also 2000 rms each w a Memphis 4k and had no probs so uve heard I should be ok w what I have
Josh
Old 09-06-2012, 12:24 AM
xnewbx's Avatar
0/11 ssssss985
There are some things you should not cheap out on, your electrical system is the #1. A h/o alt would solve about every problem you will have for quite some time and as you mention you have at least one big battery. There is really no way around it to get clean power. Power must come from somewhere. Sorry if I'm being somewhat blunt about it.
Old 09-06-2012, 10:34 AM
LoudnProud's Avatar
0/11 ssssss992
Hit up excessive amperage! Or another dealer on here. Had a great experience dealing with Nate. Quality handmade product too. Good luck deciding man that's the fun part.
Old 09-06-2012, 10:35 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
you need both, bottom line
(2) HDD12's
on a SAZ4500
2 Memphis MOJO 12's in a Mustang-Mitch's Car Audio Install-The Last One :( twistedchild420 Car Audio Videos 1 11-30-2011 06:00 PM
Kicker Install @ Mitch's Car Audio twistedchild420 Car Audio Videos 2 08-30-2011 11:19 AM
Need car alarm install help k3n12ock General Car Audio Discussion & Questions 1 03-30-2010 12:46 AM
install, but not in a car ftl. 56k beware silvercookie Off Topic Chat 19 08-27-2008 08:53 PM
