Big 3 in 2/0 any difference? - Car Audio Classifieds!
Old 09-06-2012, 11:40 AM
Contributor
0/11 ssssss527
Default Big 3 in 2/0 any difference?
I had previously done the Big 3 in CCA 0 ga. but I got a good deal on some pre-made 2/0 welding cables (18" for charge lead, 36" batt to frame, 24" batt to engine) and plan on swapping out my 0ga. for the 2/0. I know there will be less resistance, but will I notice is what I'm really curious about. Anyone done this? Is there an advantage to using 2/0 over 1/0 besides the obvious?
Old 09-06-2012, 11:44 AM
0/11 ssssss244
Unless you were maxing out the 0 gauge, like trying to pull 300+ amps through it. (A 2ft run of 0 gauge is good for about 350, so we'll say the CCA is good for 300) then you probably won't notice a difference.
If you have a stock alt then there's an even slimmer chance that you'll notice the difference.
Old 09-06-2012, 11:47 AM
Supergumby5000's Avatar
0/11 ssssss642
Unless you were exceeding the capabilities of the 0awg, no you wont notice the difference.
You would need a serious charging system to need anything larger than 0awg.
Old 09-06-2012, 11:48 AM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
On top of that, 2/0 welding cable is typically smaller than 2/0 CA power wire on the big brands. 1/0 Knu, Kicker, RF, AT are all very oversized and closer to 2/0. You wouldn't be gaining much, I would dare say not worth it unless you could sell off your old wire to cover the cost and/or you are at absolute max current potential on the 1/0 as stated by an-i-no
Yep, remember 1/0 will carry all of the current a ~300A alt can put out.
Stupid Loud.
Old 09-06-2012, 03:33 PM
LoudnProud's Avatar
0/11 ssssss992
Stick with the 1/0 save yourself some $
Old 09-06-2012, 10:24 PM
Contributor
0/11 ssssss527
I already bought the cable it was less than I can sell my current 1/0 for. Way less. I have a 270a alt and I don't have dedicated 1/0 ground run to the back so I figured it may help.
Old 09-06-2012, 10:49 PM
Use both. 600 amps of carrying capability FTW!
Old 09-06-2012, 11:32 PM
Contributor
0/11 ssssss527
I like your style.
whats da big difference in saz3500vsbc3500 audio man General Car Audio Discussion & Questions 6 01-27-2012 07:10 PM
Is there a big difference from dynomat to something like peel n' seal? two8w7 Sound Deadening & Fabrication 65 11-29-2011 04:27 PM
Think it will make a big difference? bunkrd you2 General Car Audio Discussion & Questions 3 06-19-2011 04:20 PM
Big Difference? Hdorre General Car Audio Discussion & Questions 34 08-20-2010 08:25 PM
Never went from sealed to ported, big difference? hornedfrog1985 General Car Audio Discussion & Questions 23 07-23-2009 11:08 PM
