spl gains from bolting box down?? - Car Audio Classifieds!
Old 09-06-2012, 07:21 PM
0/11 ssssss437
Default spl gains from bolting box down??
has anyone done any true testing with bolting,strapping there box down?
I'm only testing with 1400 watts at the moment but the box jumps around like crazy.
I have not found my box placement yet or I would bolt it down or something but i dont want multiple holes every where from the bolts
Old 09-06-2012, 07:43 PM
Wait for it.....
WAIT FOR IT........
Ya, it helps reduce "box rise".
Old 09-06-2012, 07:44 PM
0/11 ssssss989
^^ lmaoo
Old 09-06-2012, 07:45 PM
Sorry, had to do it. Kind of an inside joke.
Yes, you will definitely gain. It's all about energy transfer, if your expending energy on the box (or baffle for that matter) bouncing around, that's less energy that will be available to produce acoustic output. Depending on the size of the box, you could just use velcro to at least keep it stable.
Old 09-06-2012, 07:49 PM
0/11 ssssss437
Originally Posted by SPLEclipse View Post
Wait for it.....
WAIT FOR IT........
thanx i will get on strapping it down from now on and will report back with my results. probably tomorrow afternoon.because i cant test at the house
Old 09-06-2012, 08:01 PM
Ronmeister's Avatar
0/11 ssssss791
Use multiple straps. One going around the enclosure longitudinally and one perpendicular to that one depending on you have your woofer/port placement. That'll give you an idea on loss from enclosure flex.
Then, if you have something solid and secure to bolt down to, definitely go for it. Because I would hate to have newbs thinking that screwing their enlosure down to the false floor/foam carpet pad trunk well/spare wheel cover will gain them anything lolol. Although I will say, that I have gained several tenths by ratchet strapping the heck out of an enclosure once. But then after using that for proof of concept I simply better braced the enclosure and it performed just as well lol.
Ron
Old 09-06-2012, 08:02 PM
0/11 sssss2094
Wait for it.....
WAIT FOR IT........
You just could not resist it...... couldn't you.
Old 09-06-2012, 08:07 PM
0/11 sssss1184
Wait for it.....
WAIT FOR IT........
Wow I'm glad I'm home alone, Roomates would think I went mad with laughter
Old 09-06-2012, 08:14 PM
LoudnProud's Avatar
0/11 ssssss992
Wait for it.....
WAIT FOR IT........
Old 09-06-2012, 09:15 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Unless your running 1000's of watts, I don't think it would increase spl much. My box is bolted down, either strapped or bolted, should be anyway to prevent movement.
bolting down boxes from moving... darkkon General Car Audio Discussion & Questions 6 11-11-2011 04:37 PM
Bolting a heavy sub onto a wall walled01alero General Car Audio Discussion & Questions 5 07-22-2011 11:16 PM
bolting amp to the box davidrforbus General Car Audio Discussion & Questions 23 06-10-2010 03:47 PM
Box Modification SPL Gains sundownz (Sundown Audio) 36 08-27-2009 04:02 PM
Sound Dampener to SPL Gains sundownz (Sundown Audio) 6 05-13-2009 01:41 PM
