Any ways to test a sub amp without any subs to use? - Car Audio Classifieds!
Old 09-06-2012, 08:52 PM
Wingman0121's Avatar
0/11 sssss2171
Default Any ways to test a sub amp without any subs to use?
Is there any way to test a subwoofer amplifier's functionality without having any spare subs to test it with?
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
any speaker?
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
Old 09-06-2012, 08:56 PM
Ricksi30's Avatar
0/11 ssssss997
Turn the gain all the way down and use a speaker. Then turn the gain up slowly.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 09-06-2012, 08:58 PM
xnewbx's Avatar
0/11 ssssss985
Well couldn't you hook up a dmm to it and get some voltage readings? You probably won't be able to tell if it is sending a crapped out signal though, but neither would you with a speaker...
Old 09-06-2012, 09:02 PM
0/11 sssss2171
I could but like you mentioned I want to make sure it is outputting good signal. I don't have any spare sub/speakers right now and the amp I'm testing is a 2000 watter. I want to at least get the amp going to like a quarter volume (so a few hundred watts) to make sure everything is good. I plan on selling it.
Pretty pathetic that I don't have any subs sitting around. Usually I have at least one or two.
Old 09-06-2012, 09:05 PM
Ricksi30's Avatar
0/11 ssssss997
Go to a local shop and ask them to test it.
Team SSA
Old 09-06-2012, 09:12 PM
0/11 sssss2171
Already asked, mofo wanted $25
Old 09-06-2012, 09:23 PM
Last I checked, dummy loads for 2kw were like $400. You seriously don't have a sub anywhere? Can't you pull one from your car or computer/HT setup?
Old 09-06-2012, 09:26 PM
0/11 sssss1364
Feedback Score: 25 reviews
take it to the pawn shop and say u had it in ur basement and u think u want to sell but u dont know if it works. lol they will test it and just say u will think about there offer
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Old 09-06-2012, 09:31 PM
Originally Posted by assassin1840 View Post
take it to the pawn shop and say u had it in ur basement and u think u want to sell but u dont know if it works. lol they will destroy it and drop it on the way back to the bench and just say u will think about there offer
Fixed. Pawn shop guys know less about car audio than 5 year olds.
Vibration test results - P&S or not to P&S, that is the question... Second Skin Rep Jon Sound Deadening & Fabrication 96 06-17-2014 12:53 AM
6 iraggi alts 1000amp load test&single 380 test 98HOEONSIXEZ Car Audio Videos 21 06-11-2010 09:24 AM
What do you guys use to free air test subs in your house? AuZy_AuDiO General Car Audio Discussion & Questions 22 06-07-2010 12:16 PM
shop test amp? Violence* Off Topic Chat 3 06-01-2010 04:06 AM
Someone to test amps and subs near Raleigh NC DS Autosports General Car Audio Discussion & Questions 8 12-10-2009 05:57 PM
