can someone walk me through how to hook up a ohio gen regulator - Car Audio Classifieds!
Old 09-06-2012, 11:07 PM
cav950015s's Avatar
0/11 ssssss745
Default can someone walk me through how to hook up a ohio gen regulator
Can someone walk me through how to hook up a ohio generator adjustable voltage regulator.i have a ohio gen 16 volt external regulated alternator.i know the field wire goes to wire on alt but does the power for the regulator have to be 12 or 16 volts and then ground.im runing dual 8 volt batterys to do 16 volts so any help would be appreciated.this is a 2nd alt i still run my stock alt for the car the 16 volts is only for my amps.
2004 chevy cavalier ls sport.double din pioneer head unit.two deka batteries in the trunk.3 runs of zero gauge and 3 300 amp fuses.sound digital 8k amp.two dd9512gs.4 cube box tuned to 40 hrz with 8 inch aero port firing into cab 150 is best i have done sealed up so far.took 3rd place at world finals 2012 1001 to unlimited class.
Old 09-07-2012, 02:41 PM
cav950015s's Avatar
0/11 ssssss745
Nobody knows how to wire this.
Old 09-07-2012, 05:13 PM
0/11 ssssss437
well ive never ran mine separate. so i always hooked the 12 volt wire to a switched wire like ignition. so i would start there and then make sure it adjust's then if it dont work hook it to the 16volt side. either way wont hurt it.
Old 09-07-2012, 05:21 PM
Austin175's Avatar
0/11 sssss4224
Do you have a picture?
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 09-10-2012, 01:53 PM
cav950015s's Avatar
0/11 ssssss745
the regulator is the 911-2r blue box from ohio gen
Old 09-10-2012, 02:14 PM
Gabriel ruiz's Avatar
0/11 sssss1458
Feedback Score: 37 reviews
Use a 12v to power the regulator that's all it needs.and then use a switch or a relay to power on the regulator when needed
Old 09-10-2012, 02:17 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
External regulator wiring How to part 1 - YouTube
External regulator How to part 2 - YouTube
The Following User Says Thank You to audioarsonal For This Useful Post:
crunkjuice1 (09-10-2012)
Old 09-10-2012, 05:08 PM
cav950015s's Avatar
0/11 ssssss745
Talked to nate at excessive sounds like i have to run 16 volts to the power side of regulator since im running a 16 volt system.
Old 09-10-2012, 05:30 PM
Ja Marcus
0/11 sssss6975
Do you have 16v batteries?
Old 09-10-2012, 07:14 PM
cav950015s's Avatar
0/11 ssssss745
No i have daul 8 volt tractor batteries but the will be run in parr or series to get 16 volts
Ohio gen for 2.4l toyota jpassage24 Wiring, Electrical & Other Installation Equipment 7 05-02-2012 06:47 PM
300a Ohio Gen alternator - GM jnknzz Wiring, Electrical & Other Installation Equipment 13 04-16-2012 08:40 PM
210 amp ohio gen and ext regulator GODHATESCIVICS Wiring, Electrical & Other Installation Equipment 11 11-08-2010 12:28 PM
How to hook up Mechman external regulator to mechman 270 87linkin General Car Audio Discussion & Questions 6 06-21-2010 12:55 AM
ohio generator volt regulator (blue box) psychoacoustics Wiring, Electrical & Other Installation Equipment 0 06-18-2009 10:19 PM
