Wiring up a 2 wire volt meter from china - Car Audio Classifieds!
Old 09-08-2012, 06:35 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Default Wiring up a 2 wire volt meter from china
So I bought the 2 wire volt meter from china and was wondering if I could connect the positive to my amps remote wire. I tried the positive to the HU power and amp power but it stays in if I do. With the remote on the amp, the meter will turn on and off with the radio. In just not sure if this will mess anything up and if it is accurate like that. Any thoughts?
Sent from Uranus
Old 09-08-2012, 07:10 PM
Mr.G6's Avatar
0/11 sssss4614
well using the positive lead to the radio will NOT be the same as the at the amp
do not use that
just install a simple switch simple as that
regualr remote switch work 100%
2000 Gmc Sonoma ext cab
Old 09-08-2012, 07:17 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
You could use a switch or a relay.
A switch leaves you to turn it off every time. A relay will make it turn on and off with the amp and you can meter the power directly at the amp.
Team CACO Team SHOK
Supporting Member
Old 09-08-2012, 07:18 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
So your basic toggle switch they sell at autoparts stores will work then? Cool.
Sent from Uranus
Old 09-08-2012, 07:21 PM
Sent from Uranus
Yup. I wouldn't worry if you leave it on either. The current draw is very low, it would probably take months to drain the battery.
Old 09-08-2012, 07:27 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Sent from Uranus
what meter did you buy? i bought 3 different ones that differ in size and 2 are adjustable. only 1 was a 3 wire.
My game is legit,
Old 09-08-2012, 07:30 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
a toggle switch will work just fine.
Old 09-08-2012, 07:40 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Thanks guys. Byron not sure. It's small and the pos/neg wires hook up to the meter by a little connector thing.
Sent from Uranus
volt meter wiring Hertchu General Car Audio Discussion & Questions 10 02-22-2012 04:34 PM
WTB: Volt meter, fuse holders, fuses, 1/0 wire, PAC LC-1, etc 727Designs Wanting to Buy (WTB) 7 01-30-2012 02:08 PM
all new install parts, wire, fuses, fuse holders, volt meter 98Expo Wiring, Electrical & Other Installation Equipment 4 11-29-2011 03:21 PM
ground wire and led volt meter premierdime Wanting to Buy (WTB) 4 11-08-2010 09:25 AM
[FOUND] Stinger volt meter, or any other digital volt meter... andrewtexas123 Wanting to Buy (WTB) 8 09-20-2010 10:50 PM
