box building debate - Car Audio Classifieds!
Old 09-08-2012, 07:22 PM
mikeredam's Avatar
0/11 sssss1201
Feedback Score: 50 reviews
Default box building debate
ok so i have a monster 15" sub on the way and wanted to do a "trunk wall" setup, however i am new to that type of enclosure. i have experienced just simply facing my subs and port in from the trunk but not sealed off and it wasnt as loud and didnt sound as good. so my question is, are trunk wall type setups with sub/port firing in the car and sealed off are they going to sound good and be loud or am i better off just doing a traditional sub/port firing back
Old 09-08-2012, 07:27 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
depends on the car and enclosure. when i sealed mine i was .7 louder that it rear firing and it sounded alot cleaner. The port wasnt proper for my car though. I just put in a new box sealed it. just waiting on an amp ive seen a huge gain from just changing ports and leaving it rear firing or forward firing without knowing the car its hard to tell. You could just open the trunk when you have it facing forward and see if you like it. it will give you the same effect as sealing the wall.
Old 09-08-2012, 07:28 PM
0/11 sssss1898
I have never had good luck doing more than a good pair of 12's in a trunk for a daily driver.
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 09-08-2012, 07:31 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
completely misread your post.
Old 09-08-2012, 08:02 PM
0/11 sssss1943
Sub and port back for a 15 in the trunk will probably rattle a lot more than forward and sealed off.
Old 09-08-2012, 08:13 PM
Ricksi30's Avatar
0/11 ssssss997
Depends on the car, but in mine it is louder to the ear and sounds much better firing into the cabin sealed off.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 09-08-2012, 10:21 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
as long as your ready to seal off your trunk and the work that comes with it compared to slapping a box together and throwing it in...
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 09-08-2012, 10:22 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
yup. my car has sat for 1 week because im sealing the eff out of her
Old 09-09-2012, 12:17 PM
mikeredam's Avatar
0/11 sssss1201
i am new to sealing off the trunk, any advice?
Old 09-09-2012, 02:19 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
great stuff spray foam in a black can is your friend. the red can for small stuff
Box building help AllenH427 General Car Audio Discussion & Questions 6 10-10-2011 08:19 PM
Building a Box for 13 w7 KRestevan Enclosure Discussion & Design Construction Help 6 03-22-2010 11:28 PM
Building first box. KcRidin09 Enclosure Discussion & Design Construction Help 6 03-19-2010 02:00 PM
Building a box for myself. Allstar71 Enclosure Discussion & Design Construction Help 28 11-03-2009 08:19 AM
New to box building.. Mojo Enclosure Discussion & Design Construction Help 37 03-19-2009 10:29 PM
