need to know whats going to help the most right now - Car Audio Classifieds!
Old 09-09-2012, 06:38 PM
crazybones2084's Avatar
0/11 ssssss536
Default need to know whats going to help the most right now
well i got my 2 Zv3 15s in a roughly 7^ft after displacement on a saz3.5k at .5 nominal in the trunk of my deville i currently have 2 runs of + and one run - from front to rear and big three done i have a hc1800 under hood with a power bastards 240a alt that has help up great for years now and 2 spv 70s in the trunk but with my bigger setup im stuck on whether to add 2 more batts or get a new alt ?" and if alt which company is your preference and if batts how many more ah am i needing ? thanks oh im dropping from around 14.4 cruising to around 12.6 and idle i havent put to much stress on as i dont care to blow something up but did see and even 12v before backing off at idle !!
[SIGPIC]COMING SOON...4-Sundown Zv3 15 d2's
2-SAZ 3500 @ .5 nominal
Audio technix deadner and 1/0 throughout
IA 6.4 for mids and highs
alot of other undecided goodies as well
Old 09-09-2012, 07:40 PM
maverickdog8's Avatar
0/11 sssss2979
I would go with a better alt. singer makes amazing alts and it seems that irragi alts are back on the rise after the bad rap they got awhile back. Your batteries are only as good as what's charging them.
Old 09-09-2012, 11:41 PM
LoudnProud's Avatar
0/11 ssssss992
I agree u need an Alt. Excessive Amperage is the road I took and I have no regrets. Nate is an awesome guy and he backs his product 100%, EA FTW!
The Following User Says Thank You to LoudnProud For This Useful Post:
goatskindreams (09-10-2012)
Old 09-09-2012, 11:48 PM
Wingman0121's Avatar
0/11 sssss2171
95 Deville with the 4.9 I'm guessing? I have a 98 Deville with the 4.6 Northstar and my alternator is under my car
Did you remove the trunk carpet and the fuse rack behind the rearseat? You should experience a noticeable amount of bass gain if you take the carpet out and cut the fuse rack in half and move it to the side. You can also remove the piece of leather behind the rearseat armrest to let the bass though. I even went ahead and got rid of m 6x9s and made fiberglass pods on the B-pillar for the rear passengers.
Old 09-10-2012, 12:03 AM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
Whens the last time you charged your batterys to full? Give your alt a fighting chance.
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 09-10-2012, 12:35 AM
0/11 ssssss536
Yea 4.9l everything you've mentioned has been done already besides the relays and whatnot attached to back seat but I have to keep seat up (kids) so I didn't move that stuff. I did cut out the steel and pulled down the leather strip a while back. 6x9s are gone and the steel between them was removed as well. Just enough left to hold up og rear deck covers and 3rd brake light. I have not put them on a charger in a hot min I'll throw it on the charger tomorrow
Old 09-10-2012, 12:58 AM
0/11 ssssss536
ImageUploadedByTapatalk1347256638.120897.jpgthis is my ish in the trunk as it was being put in
Whats up AQ28576 New Member Orientation 4 11-17-2011 10:28 AM
whats the value thel.t.d.supply General Car Audio Discussion & Questions 2 06-21-2011 11:13 AM
Whats up Roadrash New Member Orientation 2 06-09-2011 02:15 AM
Whats up Silverado_SS New Member Orientation 16 10-29-2009 06:59 PM
