Wiring help please - Car Audio Classifieds!
Old 09-10-2012, 12:51 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Default Wiring help please
i got 4 d4 subs i wanna wire at .5, so all my wires will end up in one final run, so what channel do i use on my dc 3.5k?
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 09-10-2012, 01:49 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
what the hell?
there is only one channel on your dc3.5k
run everything parallel
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 09-10-2012, 01:50 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
Subwoofer Wiring Diagrams, Four 4 ohm Dual Voice Coil (DVC) Speakers
Umm, it's only one channel, so you can wire to whichever pair of positive/negative terminals you want. They give you two pairs to make wiring easier. Unless I'm retarded.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 09-10-2012, 01:52 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
You can wire two subs down to one ohm and plug each pair into the two channels and get half ohm or run them all in parallel and get half ohm
'02 trailblazer
4 c2 threatcon 2 12s
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 09-10-2012, 02:12 PM
0/11 sssss1813
Is one better then another?
4xSundown sa-8''s
Old 09-10-2012, 02:13 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
It'll be easier to plug them into both channels. Look a little better as well.
'02 trailblazer
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 09-10-2012, 02:14 PM
0/11 sssss1813
But no better power transfer?
4xSundown sa-8''s
Old 09-10-2012, 02:16 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
I don't really know what you mean by that. But they will receive the same power. The channels are connected on the inside so really you are plugging them all in the same channel.
'02 trailblazer
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 09-10-2012, 02:23 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
This^
Sent from my SPH-D700 using Tapatalk 2
Wiring help Landon75 General Car Audio Discussion & Questions 1 06-01-2011 03:14 PM
Need help wiring mxdustinmx General Car Audio Discussion & Questions 9 02-08-2011 03:00 PM
Sub Wiring help CivicWithTehBeat General Car Audio Discussion & Questions 6 12-12-2010 10:34 PM
Wiring Help LOUDHOE General Car Audio Discussion & Questions 11 10-04-2009 10:02 PM
Sub Wiring Help dkhage1 General Car Audio Discussion & Questions 4 01-19-2009 09:22 PM
