M4a or 2 m3as? - Car Audio Classifieds!
Old 09-13-2012, 09:53 AM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Feedback Score: 17 reviews
Default M4a or 2 m3as?
Need help with amp choice. M4a wired at .75 or two m3as strapped at 1.2. Rise is 1.5ish in my truck on a single amp. Let's say voltage drops to 14v, input please
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 09-13-2012, 10:08 AM
0/11 sssss1968
Feedback Score: 25 reviews
strap the m3as at .75. i ran mine at .25 for 2 months and only shut off once at a comp but it was 95 degrees outside. beast ampsmy voltage was never blow 13 at full tilt
Old 09-13-2012, 10:13 AM
AbsoluteAudio's Avatar
0/11 sssss1133
2 of the new M3b's strapped . I pulled 8k+ out of mine strapped @ 1ohm 13.3v.
Old 09-13-2012, 10:18 AM
theddman83's Avatar
0/11 ssssss358
i would do the 2 m3s
did a 151.5 with 5 3512" on 3700 watts at 34hz
Old 09-13-2012, 10:27 AM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Each would see like .4 each is that safe? 7 d3100s 600 amps of alt
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 09-13-2012, 10:29 AM
LoudnProud's Avatar
0/11 ssssss992
Yeah you should be fine man. Strap em' up!
0/11 sssss1968
ya had stock alt. 2 runs of 0/1 to the trunk and 2 group 31s. got warm but never hot except from heat out side
Old 09-13-2012, 10:39 AM
0/11 ssssss761
How low can you wire the subs down? If you can get it where after rise is just under 1 the M4a will do a shit ton of power
J.D. Merkle
TEAM SOUTH
4 DD 9512H
2 DD M4a
Old 09-13-2012, 10:54 AM
ltr450racer690's Avatar
0/11 sssss3414
12 ap mini's
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 09-13-2012, 11:01 AM
ddbump's Avatar
Loyal Member
0/11 sssss2385
I have 12 d2 15s. Rise is up to 2.2 from .75 with m4a. This is a demo vehicle so it needs to be reliable
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
dd m4a klilflipp Wanting to Buy (WTB) 3 04-20-2012 05:53 PM
DD M4a truespartan9584 Mono Amplifiers 62 04-07-2012 09:59 AM
ns-1 vs dd m4a Dbeez (Sundown Audio) 46 03-15-2012 10:08 AM
DD M4a truespartan9584 Mono Amplifiers 13 01-19-2012 07:19 PM
2x DD m4a shaker1 Wanting to Buy (WTB) 2 11-01-2011 06:21 PM
