Cracking the window - Car Audio Classifieds!
Old 09-14-2012, 09:28 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Default Cracking the window
Well.. I noticed water getting into my car when I stepped in it a couple weeks back and a puddle of water was laughing at my feet. Just today I notice there is a crack in the lower left corner of my driver's side window, which is where the water must be coming from. Will siliconing the bottom part (where the water must be coming in from) work?
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 09-14-2012, 10:50 AM
Like putting silicon over the crack in the glass? I would image the first time you rolled the window down that would peel off. You'll probably have to use some sort of epoxy.
Old 09-14-2012, 11:58 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
It's on the front windshield, not the side windows.
yeeeahhh.
Old 09-14-2012, 12:09 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
its worth a try, (fairly cheap)
but if that doesnt do it,
your better off finding someone that is good at removing windshields
with out breaking them,
then redo the whole seal
Old 09-14-2012, 12:11 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Well..if I remove the window...the cracked piece in the corner will probably stay on the seam (It looks like a pretty deep crack)
yeeeahhh.
Old 09-14-2012, 12:21 PM
tacomaguy1's Avatar
0/11 sssss4401
the way you worded it sounded like you meant driver side roll up window
I don't think silicone would work, time for a new one
you said a puddle by your feet? I don't think a crack on the bottom side of windshield would do that.....so it's coming in and going behind the dash, and then onto the carpet
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-14-2012, 12:30 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
I'll have to double check it, but it looks like that's the source...it happens when my car is at stand still and it starts to rain...nothing else is wet. Just the floor.
yeeeahhh.
Old 09-14-2012, 12:56 PM
Wingman0121's Avatar
0/11 sssss2171
Take it to your local auto glass specialist and see what they say.
OEM wire's insulation cracking (from heat?). Will liquid electrical tape work? Vital Off Topic Chat 1 09-08-2012 07:44 AM
need help with window motor. hornedfrog1985 General Automotive Chat 14 08-28-2010 11:37 AM
Window Tinting Bologna General Automotive Chat 24 07-07-2010 11:14 PM
Omega surround cracking repair amartin_72 General Car Audio Discussion & Questions 2 06-14-2010 10:04 PM
Window crank. davidrforbus General Car Audio Discussion & Questions 5 05-02-2010 11:19 AM
