Car Audio Rules of Thumb? - Car Audio Classifieds!
Old 09-14-2012, 12:28 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default Car Audio Rules of Thumb?
So every once and awhile i see someone throw out a little known fact in the car audio world that the new guys don't know, Little tricks of the trade, do's and dont's. This thread will be for everyone to give their little secrets and just unwritten rules. I'm sure i can learn a lot from this also. Whether its true or not, all that matters is that it has helped you, because it could help someone else too. Let's keep the finger pointing and mean comments in another thread please.
I'll start:
Your port should never be less than 4-6" away from any walls or objects.
Old 09-14-2012, 12:32 PM
tacomaguy1's Avatar
0/11 sssss4401
don't put more then 500w on a funky pup or you'll shatter your windshield
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
The Following 3 Users Say Thank You to tacomaguy1 For This Useful Post:
Goindef154 (09-15-2012), theddman83 (09-14-2012), topdawg (09-14-2012)
Old 09-14-2012, 12:33 PM
Mr.G6's Avatar
0/11 sssss4614
general rule of thumb for port area
12 to 16" per cube for slot ports.
ive had luck with 6 to 12" per on aeroports
2000 Gmc Sonoma ext cab
Old 09-14-2012, 12:36 PM
Ryan1126's Avatar
0/11 sssss9178
obviously...
Old 09-14-2012, 12:54 PM
Wingman0121's Avatar
0/11 sssss2171
MAX power rating don't mean shit.
The Following User Says Thank You to Wingman0121 For This Useful Post:
BallzFast (09-14-2012)
Old 09-14-2012, 12:55 PM
Mr.G6's Avatar
0/11 sssss4614
nevr run rca's and power n ground wires side by side
The Following User Says Thank You to Mr.G6 For This Useful Post:
05LGT (09-14-2012)
Old 09-14-2012, 01:11 PM
0/11 sssss1411
Picking Driver & Crossover Points:
When crossing tweeters (low end response), the general rule of thumb is twice the F's (resonant frequency) at 12db.
"Check over at Dogma.com"
Edit: I mean Diyma!
The Following User Says Thank You to 05LGT For This Useful Post:
Fatboy501 (09-14-2012)
Old 09-14-2012, 01:15 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
you can get a general idea of what kind of power your amp should be putting out
by the fuse rating
multiply the fuse amps X 10
i.e. : 40 amp fuse x 10 = 400 rms, (ballpark figure, in a perfect world)
Old 09-14-2012, 01:19 PM
0/11 sssss1184
Power wire should match ground wire in size
Old 09-14-2012, 02:49 PM
Matt3824's Avatar
0/11 sssss3754
Maximum of 1:9 port height:width ratio. For example, don't do a port 2" tall and 28" wide.
Rule of thumb on width of port. davidrforbus Enclosure Discussion & Design Construction Help 24 08-03-2012 01:29 PM
fastest thumb drives? slowpoke General Car Audio Discussion & Questions 7 06-02-2012 12:34 AM
Check your thumb Violence* Off Topic Chat 9 07-06-2010 08:10 PM
