Lets talk 2V and 4V cells - Car Audio Classifieds!
Old 09-15-2012, 10:44 AM
murderedtahoe's Avatar
Mr. Low End Monster
0/11 sssss3512
Default Lets talk 2V and 4V cells
havent been on here in a while, so im looking threw threads and i see people are adding 2v cells in there system making it a 14V bank, so can you guess shed some light on this? what type of cells are used? whats the benefit of using them besides 14v? ive heard that mixing these with other batts would not be good, being that current draw would kill the smaller batts quick, much like using triple A batteries in series to make 16v, but just because its 16V dont mean it can take a big current draw. can anyone clarify this?
Old 09-15-2012, 12:29 PM
SPL Distribution Owner
0/11 sssss2983
Your analogy is right and you could have answered your own question with it too..
I'll give you another one.
When series-ing batteries, the ONLY thing that changes is voltage.
So by saying that.. let's look at a 12v battery.
a 12v battery has 6 cells in series.
That means that each cell can do the same current value.
that means, if you take a Odyssey PC2150, EACH CELL can output 2,150A for 5 sec, 5000A for 0.1sec, etc...
So, when looking for 2v cells, make sure you match similar ratings to your existing batteries.
Also, i would only advise doing this for competition only. If for daily, i'd HIGHLY recommend putting a solenoid in between EVERY 12v to 2v cell combination you have to prevent your batts and cells from killing each other in the long run.
Old 09-15-2012, 12:38 PM
Mr. Low End Monster
0/11 sssss3512
so would adding 2v cells with a strong 12v batt be as good as buying a xs 14v batt
Old 09-15-2012, 12:41 PM
0/11 sssss2983
Xs 14v battery is only 50-60ah at ~2400-2600 SCA.
If u have a 12v batt and 2v cell with ampacity rating greater than that,
Then it's very likely to be more powerful.
Old 09-15-2012, 12:44 PM
Mr. Low End Monster
0/11 sssss3512
so how would i go by when it comes to matching 2v cells to a 12V batt? AH rating or what? would it beok to wire more than one 2vcell in parallel to increase rating then wire the last cell in series with the 12v? or how would that all work anyway?
Old 09-15-2012, 12:47 PM
0/11 sssss2983
Id be matching max amps/ short circuit rating.
AH isn't going to be a good spec to match with.
Series only. Parallel is pointless and expensive.
Old 09-15-2012, 02:01 PM
HACKMUNCH's Avatar
0/11 sssss3892
I run 14v batts and will never go back to 12v.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 09-15-2012, 02:11 PM
Mr. Low End Monster
0/11 sssss3512
hmmmmmm......... where can i find some of these cells?
Old 09-15-2012, 02:16 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
16 or 15 volt charging system?
Old 09-15-2012, 02:21 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Don't waste your time.
lets talk computers mcmuffin Off Topic Chat 26 08-26-2011 11:33 AM
lets talk HU Kyle K General Car Audio Discussion & Questions 26 10-08-2010 12:43 PM
lets talk mids splvictim20 Sound Quality Area 34 09-29-2010 05:49 AM
lets talk some music splvictim20 Competition Corner 6 09-03-2009 01:12 PM
