Replace busted inductor... Help!!! - Car Audio Classifieds!
Old 09-15-2012, 08:42 PM
0/11 ssssss276
Default Replace busted inductor... Help!!!
So my inductor coil on my crossover busted off today and can't really get to the wire to solder it back on...
So here is what the crossover shows for the type:
0.2mH1.0
I'm guessing its basically this:
Jantzen 0.20mH 18 AWG Air Core Inductor 255-210
but there are different gauges that are available... Not to sure what to buy for a replacement...
Old 09-16-2012, 12:06 AM
Prohibited Sellers/Buyers
0/11 sssss1770
can u count the turns on it?
Old 09-16-2012, 08:38 AM
0/11 sssss2429
Feedback Score: 46 reviews
You need a micrometer to measure the thickness to find the correct gauge wire.
Old 09-16-2012, 08:44 AM
0/11 ssssss276
Yep... getting between 6-8 turns depending on the side... Going by dims the 18 won't fit right and 20 seems to be right on accept the height...
Old 09-16-2012, 09:47 AM
0/11 ssss31258
I do not suggest rewinding the coil.
I do suggest soldering an extension on the existing wire.
as long as the extension piece you solder on is more conductive than the wire of the inductor, the value of the inductor will not change. (if you use solid copper, then 16 gauge will be fine)
Old 09-16-2012, 12:26 PM
0/11 ssssss276
Thing is can't get to the existing wire without compromising the existing coil our I would do what you've said...
won't be rewinding it... Basically going to lop the one of and solder the new one on... 20 gauge will fit the foot print... Same inductance value and similar size
(busted?) Soundstream Reference 700sx thejasond Broken & Non-working equipment 2 02-21-2012 01:42 PM
Bought a table saw. Busted Rip Fence CousinVin Enclosure Discussion & Design Construction Help 8 12-31-2011 05:23 PM
Busted Subs... PLEASE HELP cjbellmore General Car Audio Discussion & Questions 32 09-05-2010 06:33 PM
Busted voice coil rodpgfx General Car Audio Discussion & Questions 0 05-08-2010 02:49 PM
busted the oil pan on the audi a4 snoopysnooper Off Topic Chat 14 06-07-2009 04:58 AM
