Severe Voltage Drops - Car Audio Classifieds!
Old 09-16-2012, 02:32 PM
xnewbx's Avatar
0/11 ssssss985
Default Severe Voltage Drops
Ok so I finally got my voltage meter installed and WOW. I have some hefty voltage drops, let me point them out.
1. Volume 0, car idle, voltage drops slowly ( watched go down to 12 from 14 )
2. I don't know if this is the same for everyone, but braking causes a 14.6v to go to 12.5v WTF
3.Well from #1 I can say that I do not listen to music idling cause I will hit below 13v instantly.
4. Obviously idle sucks so as long as I'm around 2k+ rpms voltage drops around .5v at full tilt. Which I feel is still bad.
My best idea ( only cause it's a cheap fix ) is that I don't have a ground running off my alternator because I was told it is already grounded to the frame of my car as is. That's my only guess.
Help?
Old 09-16-2012, 02:34 PM
massivespl's Avatar
0/11 sssss8409
sounds like your alt does almost nothing at idle?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-16-2012, 02:39 PM
xnewbx's Avatar
0/11 ssssss985
If this was the case, is it somewhat broken? or just not powerful at idle? I'm looking into some better ones but need to make it for at least 2 months on this one
Old 09-16-2012, 03:06 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
take the alt out and have it tested at autozone. Either something with the alt is messed up or you have a big wire issue.
Current Build:
#60sHereIcome
Old 09-16-2012, 03:12 PM
SPL Distribution Owner
0/11 sssss2983
Is it an aftermarket alternator? If so, they put too large of a pulley on it.
Old 09-16-2012, 03:19 PM
SINTORMAN's Avatar
0/11 sssss4907
A ground to the alt would also help with drop too.
And .5 drop is nothing man. Don't be concerned with that.
It could be too big of a pulley or your belt could be slipping.
Current Build:
#60sHereIcome
Old 09-16-2012, 03:49 PM
Mr.G6's Avatar
0/11 sssss4614
i gained .1 of a volt JUST by grounding the alternator..just use a mounting bolt and ground it to a strut tower or something and ALWAYS paint over the grounds so they dont corrode down the road..
and going from 14.4s dropping down to 13.9 14v flat is NOTHING to wrry about nothing at all
sounds like to me you have a weak stock alt and maybe the battery underhood is starting to get weak
2000 Gmc Sonoma ext cab
Old 09-16-2012, 03:51 PM
Mr.G6's Avatar
0/11 sssss4614
Help?
the motor and trans is mounted in RUBBER mounts the motor touches nothing solid..besides the metal block itssef
i always ground my alt (like i said just use a mounting bolt and ground it to a strut tower or something..some say ground to the battery which only has basically grounding point as is)
Old 09-16-2012, 03:52 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
if you can get above 13.0v above idle then i wouldn't be worrying about wiring too much.
Although you do need a ground directly off your alternator to your front battery for the big 3. My big 3 suggestion is 2 1/0 from alt ground/mount location. one going to chassis ground and one going to front battery.
you could try swapping to a smaller pulley and see if that helps.
Old 09-16-2012, 04:15 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Before you get into 1/0 big three and whatnot... What amp are you running? Anything over 12v is fine.
Fo eights in da pickup!
Dubstep drops add yours! Wes669 Off Topic Chat 24 12-05-2011 05:55 PM
want a little more voltage duke71 General Car Audio Discussion & Questions 33 03-06-2011 06:50 PM
UPS Drops the ball....er batt...again. CHEMMINS Off Topic Chat 29 11-30-2010 08:27 PM
Voltage drops, wtf? Ryan1126 General Car Audio Discussion & Questions 21 07-04-2010 01:47 AM
Dow drops below 10,000 Patrick Simmons Off Topic Chat 27 10-13-2008 07:00 PM
