what wire should i use - Car Audio Classifieds!
Old 09-16-2012, 08:18 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Default what wire should i use
im gonna buy some wire to wire up my subs, it will be 4 sa15's off a dc 3.5k, i dont wanna have to trim down 8 gauge wire, so i want either 10 or 12 gauge speaker wire, and itll be knukonceptz, i can get 100ft of TCA 10 gauge for 49 shipped or i can get 100ft of kord 12 gauge for 63 shipped, the TCA is cca 10 gauge and the kord is ofc 12 gauge, what should i get??
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 09-16-2012, 08:20 PM
truebassjunkie777's Avatar
Team Bad Intentions
0/11 ssssss632
I would say go with the OFC
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 09-16-2012, 08:22 PM
0/11 sssss1813
should be better cause its ofc? even though its smaller?
4xSundown sa-8''s
Old 09-16-2012, 08:34 PM
Team Bad Intentions
0/11 ssssss632
In my opinion yes. I have seen 8 awg cca melt befor on 4K
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 09-16-2012, 08:40 PM
0/11 sssss1813
really? thats insane
4xSundown sa-8''s
Old 09-16-2012, 08:41 PM
Mr.G6's Avatar
0/11 sssss4614
i ONLY ONLY use ofc wire
id much rather take a "cheaper" brand of ofc wire over the "high grade hype" wire
american bass wire is awesome and so is audiopipe wire..and its ofc
2000 Gmc Sonoma ext cab
Old 09-16-2012, 08:48 PM
Team Bad Intentions
0/11 ssssss632
He is running 4 SA-15s on a SAZ-3500 @.25 ohms
He switched to knu 10awg OFC and never had a problem
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 09-16-2012, 08:54 PM
Matt3824's Avatar
0/11 sssss3754
I can understand CCA for power, but I would never use it for speaker wire, but that's just me.
The Following User Says Thank You to Matt3824 For This Useful Post:
certifiednut (09-16-2012)
Old 09-16-2012, 08:58 PM
0/11 sssss1813
then ill pry do the 10 gauge ofc, i will have my 3.5k at .5 all day
4xSundown sa-8''s
The Following User Says Thank You to logan23afroman For This Useful Post:
AAKSOKOLD (09-16-2012)
Old 09-16-2012, 08:59 PM
jbizzle's Avatar
0/11 sssss4346
Feedback Score: 26 reviews
I used the TCA and its some nice stuff, go with that...
'07 Chevy Trailblazer SS AWD (Garage Queen)
- Alpine 9887
- Eclipse SC8365 3-Way front stage
- Sundown SAX-125.2
'98 Jeep Grand Cherokee (Daily)
- Alpine 9887 (Active)
- Selenium 6" Mids, 4 Crescendo CTS-1 Tweeters
- Sundown SAX-100.4D
- 2 Sundown SA-12s
- Sundown SAZ-1500Dv2
Team Sundown Audio
1/0 wire, 4awg wire, fuse holders, speaker wire, baffles, RCA...lots! dacheatham Wiring, Electrical & Other Installation Equipment 4 08-30-2012 06:16 AM
Speaker wire, power wire, battery terminals, in-line fuse holders nyoc2020 Wiring, Electrical & Other Installation Equipment 16 08-13-2012 03:51 PM
wire wire wire 2/0 1/0 4ga & speaker wire dgaf_ Wiring, Electrical & Other Installation Equipment 11 04-08-2012 08:06 AM
WTB: lots of installation stuff (RCA's, power wire, speaker wire) treylittlefield Wanting to Buy (WTB) 23 11-21-2011 01:02 PM
[SOLD]FS:125ft Monstercable 8 gauge power wire/ speaker wire treylittlefield Wiring, Electrical & Other Installation Equipment 33 08-23-2010 01:31 PM
