How high can you cross subs? - Car Audio Classifieds!
Old 01-08-2013, 12:29 PM
newarkbeast973's Avatar
1/11 sssss7810
Default How high can you cross subs?
How high can one cross subs at? I'm asking this question because I recently purchased a jbl ms-8 and I hear that you can't stagger frequency ranges! For example. If I set my mid bass 80hz-200hz, then midrange has to start at 200hz and go to 5khz and then the tweeters have to start at 5khz- and up. With the mid bass starting at 80hz then that means that the subs have to be from 25-30hz to 80hz. Is 80hz alright for subs?
New build coming soon!!
Old 01-08-2013, 12:33 PM
0/11 ssssss285
80 hz is perfect
above 80 you strat to be able to tell where the bass is coming from instead of it sorrounding you
Old 01-08-2013, 12:36 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
80hz should be fine. I personally like mines at 100/120hz depending on amp/car.
Old 01-08-2013, 12:59 PM
Ronmeister's Avatar
0/11 ssssss791
It also depends on the driver sometimes IME. The MS-8? Sure, I bet it'd be just perfect crossed at 80Hz or so.
Crossing my SHD 18" at 80Hz doesn't work out too well though Rather 63Hz seems to work great.
Old 01-08-2013, 01:13 PM
1/11 sssss7810
It's 10" m2 xl's
Old 01-08-2013, 01:18 PM
Mr.G6's Avatar
0/11 sssss4614
in my eyes these 80hz n such should be taken care of with the midbass drivers..
i keep my subsonic off and lpf around 40ish at most
but then again i hate that buzzy ass bass every1 else likes
2000 Gmc Sonoma ext cab
Old 01-08-2013, 01:37 PM
1/11 sssss7810
That's what I usually do (well I set my ssf to 20hz) but the lpf on around 40-50hz. The only reason I was thinking 80hz is because idk how low I can actually play my mid bass 8's before bottoming out.
subs cut out at high volume 1loudmonte General Car Audio Discussion & Questions 16 07-19-2012 07:34 PM
subs cutting out at high volume!! beatnbronco General Car Audio Discussion & Questions 38 04-01-2012 09:19 PM
WTB 2 12 inch Subs! High End bb6kid Wanting to Buy (WTB) 13 11-30-2010 10:52 PM
Grills for high excursion subs? Vital General Car Audio Discussion & Questions 10 09-30-2010 11:47 AM
Brand new High end amps and subs for sale! delanno25 Recycle Bin 0 09-20-2008 09:08 PM
