Sub/port Orientation - Car Audio Classifieds!
Old 01-08-2013, 12:45 PM
Drewculous's Avatar
0/11 ssssss679
Default Sub/port Orientation
I had an 01 chevy ext cab, and was running my 2 18" HDC3 woofers pointing up, and port up as well. I just bought a 06 dodge mega cab and have a ton of space to play with (im also thinking about moving up to hdc4 18" woofers)
Is the same up/up orientation the best way to go, or should i face both woofers and port towards the front of the cab... or treat it like a small SUV and do subs up, ports back? Would it really matter when i step up to the hdc4's?
thanks in advance for the input!
If the cops dont come, your not doing it rite.
Old 01-08-2013, 12:57 PM
tacomaguy1's Avatar
0/11 sssss4401
subs forward/port up works very well
subs up/port up works good too
Either will get good results
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Sub / port orientation? My first trunk car nicyousuckk Enclosure Discussion & Design Construction Help 40 12-07-2012 06:38 PM
Quasi 6th Order Bandpass port orientation... quagmire Enclosure Discussion & Design Construction Help 10 06-07-2012 10:23 PM
Port & Sub Orientation in a Corvette 528hz General Car Audio Discussion & Questions 0 03-22-2012 03:01 PM
What woofer/port orientation would you choose? (Trunk) Ronmeister Enclosure Discussion & Design Construction Help 19 11-17-2011 01:56 PM
