do i have enough power for optidrive 6000d - Car Audio Classifieds!
Old 01-09-2013, 12:00 AM
0/11 ssssss243
Default do i have enough power for optidrive 6000d
Hi folks I am running ohio gen 270-300max alt optima yellow top and batcap2000 along with stock battery upfront. One run 0gafrom front to back. The amp is bridged @2ohms on two aq hdc3 12s. Since the amp does [email protected] I was wondering if I need todo any more for that power. I am not a competitor, just curious if this is sufficient for daily pounding.
Old 01-09-2013, 12:03 AM
massivespl's Avatar
0/11 sssss8409
u should prly be good. if i was going to gun 4k i would have a 270alt and 3 3100's and 2 runs of wire
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-09-2013, 12:10 AM
0/11 sssss8594
Feedback Score: 55 reviews
i have the same amp...once it installed to full potential, im gonna be running 3 xp3000, a d5100r, 200a alt and 3 runs pos and neg...dont think ill have an issue...ran the same amp last yr on a 200a alt and 3 d3400 and didnt have too bad of drop
Enclosures
Old 01-09-2013, 09:06 AM
0/11 sssssss60
heard mixing wet cells with agms cause charging problems may want to check it out so you dont damage your gear
Old 01-09-2013, 09:51 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
i would think you should be fine while driving but i wouldn't bump too much while at an idle. your battery bank is not sufficient in my opinion.
My game is legit,
Old 01-09-2013, 10:04 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I would say with the hodge podge of batteries and only one 270 that you are gonna need more electrical. Beef up your bank to at least 5 batteries if you dont plan on addin anymore alts to the mix.
Old 01-09-2013, 10:26 AM
Mr.G6's Avatar
0/11 sssss4614
its called parasitic draw.. it happens becasue the wetcell doesnt rest at the same high voltage as the agm's do.. and IN TIME WILL shorten the life of the agms and make them weaker
the short term effects are very minimal but long term (i.e. 5 or 6 months or so) you will strart seeting the agm slowly come down
i say 300 to 400ah TOTAL battery bank and another run of postiive and negative front to back
edit.. FOR SURE more wire
you are over the limit on a single run of 0g even if it is ofc wire..
2000 Gmc Sonoma ext cab
Old 01-09-2013, 10:51 AM
Ja Marcus
0/11 sssss6975
Parasitic draw causes the batteries to "fight" each other. As one gets drawn down it then in essence becomes a "load" on the higher resting battery. That battery then pulls current from the higher battery, this cycle repeats between the batteries eventually bringing the state of charge on both batteries down. If not maintained properly this can and will cause troubles down the road. Even with all AGM batteries this can still happen. That is why when you have more then one battery interconnected you should maintain them with a charger.
Old 01-09-2013, 06:09 PM
0/11 ssssss243
well i can get another optima battery here for 100 so i keep all the batts as the sealed kind is that.i am definately going to have to run another 0ga to the back. i didn't know that mixing the batts caused that much of a problem. i always thought it was my stock alt that was killing them. ive gone through three batteries in the last 1 1/2yrs. and that was on a crossfire vr2000d! i am sure glad you guys answered my questions. oh and i have a battery charger at home, i need to put this on every night?
Old 01-09-2013, 06:47 PM
0/11 sssss1381
I ran two crescendo 3500s off 4 c&d batteries grp27 and a mechman 320 amp alt and was fine
Lanzar opti 6000d caloriu Mono Amplifiers 6 06-10-2012 07:58 AM
Cadence ZRS 6000D turkishvalo eBay 0 02-11-2012 07:28 AM
(2) Lanzar Opti 6000d Team Car Tunes Jeff Mono Amplifiers 48 09-16-2011 07:54 AM
lanzar optidrive 4000d or 6000d sancho20 Wanting to Buy (WTB) 1 03-15-2011 09:46 PM
2 lanzar opti 6000d twistajay Wanting to Buy (WTB) 6 02-19-2011 11:32 AM
