how do you hook up a second amp for mids an highs? - Car Audio Classifieds!
Old 01-09-2013, 10:57 AM
0/11 ssssss313
Default second amp for door speakers only putting out bass
guy on youtube told me since my sub amp had a in and out for rca i could hook it up like that but when i hooked it all up my mids an highs where just producing bass.. if i got a rca splitter an hooked it up behind the deck running a second line of rcas to the back would that work? an would it distort the sq?
Old 01-09-2013, 11:18 AM
Munkee's Avatar
0/11 ssssss404
Splitters would work as long it's not specifically a pre out for subwoofer...because any settings the head unit would have for that rca would affect all your rca's, or so I would presume.
If you have only have one rca preout then likely it's not only for subwoofer and you'd be good.
Old 01-09-2013, 11:19 AM
hotzie's Avatar
changin the game up
0/11 ssssss793
Does ur deck have pre outs for the front and rear and subwoofer if it does use the front or rear , don't use the one on sub amp lol
Old 01-09-2013, 11:27 AM
newarkbeast973's Avatar
0/11 sssss7810
1st step. DON'T LISTEN TO PPL ON YOUTUBE!!!
2nd step. Check the back of your head unit to see if you have more than just 1 RCA output.
Usually head units have at least 2 if not 3. Let us know.
New build coming soon!!
Old 01-09-2013, 11:31 AM
0/11 ssssss313
not sure.. the back of the radio has two plugins for rca
Old 01-09-2013, 11:46 AM
Mr.G6's Avatar
0/11 sssss4614
well then there ya go
thats going to be FRONT AND REAR/SUBWOOFER
PLZ read the sticky threads and the how to's
2000 Gmc Sonoma ext cab
Old 01-09-2013, 11:49 AM
Matt3824's Avatar
0/11 sssss3754
2? Or 2 sets?
If it has 1 set, go from radio to mids/highs amps, out to next mid/highs amp, out to sub amp.
If it has 2 sets, go from front set on back of radio to mids/highs amp and out to next mids/highs amp. Go from sub set out to sub amp.
Old 01-09-2013, 12:15 PM
0/11 ssssss313
im confused.. there are only 2 coming out the back of the radio if there are 2 in a "set" then there is 1 set
Old 01-09-2013, 12:40 PM
Mr.G6's Avatar
0/11 sssss4614
you make the MOST easiest things soooooo complicated
you have a ultra cheap headunit with 1 set of preouts
buy another deck for 100bux
Old 01-09-2013, 02:36 PM
0/11 ssssss313
pioneer deck.. so "2 sets" would be 4 individual rca plugs?
Mids & highs Bigbodylexus (Sundown Audio) 3 12-03-2012 04:11 PM
Amp for mids and highs ? Throwback559 General Car Audio Discussion & Questions 13 04-25-2012 12:24 AM
Best amp for my mids and highs? swerve225 General Car Audio Discussion & Questions 13 09-05-2011 04:15 PM
amp/ mids, highs hook-up fast4me80 General Car Audio Discussion & Questions 3 07-16-2011 11:50 PM
Amp for mids and highs install help... barber24alldaz General Car Audio Discussion & Questions 3 04-27-2010 05:30 PM
